MarkD chip + injectors = way too rich HELP!
  • nickmp0wer
    • 1427
    i put 19s in and my milage went to shit. i did it at the same time as a couple othe things so i not sure if its the cause or not, but i think im going to try swithcing them
    • Garageaholic
      Freestyle Fabricator
      • Dec 2005
      • 5204
      What else did you do in conjunction with the injectors? How was the power difference with the markd chip???.. it must be a bitch to change them in the M20. I've never changed injectors before, but i could imagine. I will be doing it in my M30 in a couple months....
      Recent Rebranding!!
      E30 SM62/S62
      E30 M60 V8
      E30 M30 Big 6!
      Instagram.com/garageaholic
      Youtube.com/garageaholic
      • parkerbink
        • Jun 2004
        • 10138
        I have Nitro's 19# & MarkD and My city milage is down freeway seems the same.
        • Mystikal
          Wheel Fitment Expert
          • 9602
          That's impossible, since your stock injectors are already 17.5lb/hr. It's only an 8% difference, despite how sad it's capabilities are the Motronic can still correct for that much.
          • Mystikal
            • 9602
            Also, FWIW, moving from 14.2lb to 17.5lb injectors in my car led to an immediate decrease in fuel consumption, along with much better throttle response (4-pintle). STILL haven't met up with Mark to dyno it again though, so no power claims.
            • Axxe
              • Aug 2004
              • 3355
              FYI 205/60R14 is spot on for odometer.
              Keep it slideways!!
              • CarsSuck
                • Oct 2005
                • 968
                Goodie
                Swapping the injectors is pretty easy, remove valve cover, pop off the electrical connectors and rail, remove four bolts and then pop those suckers off the. I tried to remove the rail from the injector and was successful on all but one. To install i put them in the ports first and then put the rail down on top.
                My mileage seems better. Ive gotten 70 miles on my last quarter tank or so of hard driving.
                --Will
                • CarsSuck
                  • Oct 2005
                  • 968
                  Well, my highway mileage looks pretty good. City mileage is CRAP. How crappy? I'll have real numbers after i replace the clutch master and slave.
                  --Will
                  • Q5Quint
                    • Jan 2005
                    • 725
                    I have 19# 4 pintle orange ones from a mustang gt~ the #24 ones are from a cobra but I don’t remember what color they are. My milage stayed the same with the stock and the new ones.
                    The econometer may be way off.
                    It usually is, but even more so when you put in bigger injectors. It measures how often the injectors are open~ The 19# injectors are opened less than the stockers. I get over 40mpg on the highway according to the gauge with my 19#, but its actually more like 27-28.
                    • EUfemia18
                      • Dec 2005
                      • 17
                      So if you were to do this conversion to 19lbs injectors all you would need would be the injectors correct? Where could you get your hands on 19lbs injectors?
                      • robmespeedy
                        • Oct 2004
                        • 561
                        The mustang 19# ( 4 pintle ) injectors ?
                        which mustangs have these injectors ?
                        give me a year and engine size .
                        I can get them at an incredible price , i work for ford .
                        i just need to know which Mustang came equipped with these .
                        • robmespeedy
                          • Oct 2004
                          • 561
                          Never mind , i found it myself .
                          I have them
                          • e30devo
                            • Aug 2005
                            • 1102
                            so for the rest of us who dont know? which ones?
                            • Scott314
                              • Jan 2005
                              • 287
                              The ones that came on the 5.0.
                              My fast says: traction control is for the faint of heart :evil:
                              • Mystikal
                                • 9602
                                Not all 5.0 motors had 4-pintle design II injectors (the only kind you should use).
