If your talking to me, As i have stated, i checked compression 151psi across all 6, timing is dead on...
as for an UPDATE: It will start right up when bump started, but not with the starter... (when u try to start with the starter it does get gas, and it does get fuel... just wont fire up)
It wont idle under 1000rpm
There is a flat spot at 3300ish RPM...
past the flat spot it runs fine....
