trans options for m30?
  • TheNiceGuy
    • Dec 2012
    • 5
    I cant seem to find much info in this, i have a 5 speed from a 95 525i i believe its a zf trans, correct me if im wrong, but my question is can i put this trans on a m30?
  • LJ851
    • 7919
    No.
    Lorin
    The M30 is God's engine.
    • pleasefixitup
      • 24
      all depends on year. usually a getrag 260 from the associated m30 chassis will work.
      they had the same trans, with different bellhousings.
      the getrag 265 had a removable bellhousing which is neat, but good luck finding one.
      anyway--do some research--that m50 motor will not take a m30 trans.
      • WatchMyDrift
        • Apr 2012
        • 62
        I think a 2002 4speed will fit....then it will blow all the gears.
        I was lucky to find an e34 535i with a 5speed.
        • South26
          • Jun 2011
          • 856
          The m30 will take a a getrag 260/5, 260/6 265. But they need to be from a m30. The e12, e28, and e34 all used the m30. There are a lot of getrag 260/5 out there from the e28 535i.
          Andy
          • dannyyisntt
            • 3141
            I believe a manual 95 525i would have a getrag 250. Not a ZF. Tho if it's an automatic it could be a ZF or a GM derived transmission.
            But regardless of it being a ZF or g250, it won't bolt up to an m30
            • wildstoats
              • Sep 2007
              • 896
              I put together some info on m30 transmissions over here: http://www.m30swap.com/index.php?title=Transmission
              • parkerbink
                • Jun 2004
                • 10138
                My '92 cabrio has a Getrag 260/5. Anyone know if it will work with an M30 from a 735?
                • lukeADE335i
                  • Apr 2013
                  • 1386
                  You can also use the Getrag 240 from the M10 if you can't find an M30 transmission - they aren't as strong, so it depends on your plans, it you have any dreams of adding a turbo down the track, then just get the stronger box straight up, but if the M30 is staying stock or close to stock it will be fine.
                  The 240mm clutch from the M30 won't fit with the G240, so there are a few options - a flywheel from RHD engineering with the M20 228mm clutch kit, an S14 or 2002 Flywheel with an S14 clutch kit, or a 215mm 318i flywheel with a HD clutch kit.
                  There's a sticky at the top of the M30 & other swaps section that goes through a bunch of options for the G240.
                  My e30: OEM+ with M30B35
                  • parkerbink
                    • Jun 2004
                    • 10138
                    Thanks, I read several threads/posts. It seems to say the 260/5 will work but that no M20 box will work. My '92 cabrio has an M20 and a 260/5 so I'm confused.
                    • TobyB
                      • 5263
                      The m20 bellhousing is in no way compatible with an M10 or an M30-
                      it's the same as the M42/m5x bellhousing, so no E36/46 will work either.
                      any m10 or M30 trans works, including E21 M10 transmissions.
                      t
                      • parkerbink
                        • Jun 2004
                        • 10138
                        So there is an m30 specific 260/5?
                        Thanks
                        • lukeADE335i
                          • Apr 2013
                          • 1386
                          Yes - e28s came with the 260/5. Some late e28s, and the e34 came with the 260/6.
                          • LJ851
                            • 7919
                            For a M30 engine you can use a transmission from M10, S14, M30, S38.
                            The bell housing size will dictate what flywheel and clutch you can use.
                            Lorin
                            • ThatOneEuroE30
                              • Dec 2013
                              • 8626
                              And I wouldn't recommend using the g240 from the m10 imo. Not meant for the torque the m30 can put out.
                              1991 318i 4dr slick top
                              Mtech 2 turbo restoration
