Another E30 M30 Swap Thread, this time with an 84 318i
  • Mr. Burns
    • Aug 2011
    • 3516
    #211
    Originally posted by the imitator
    This harness came off of a running m30b35 swap on the same motor... its an extended m20 harness though.
    Hmm interesting though..
    Can you clarify this please?
    it is an m20b25 harness but pre-spliced to work with a b35?
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
    • the imitator
      • May 2013
      • 1006
      #212
      The harness has been Extended in certain areas like spark plug wire and other necessary extensions. The harness came off a late model e30 with m30 swap, so there wasn't a need a to splice in a switched 12v source.
      But now that I've swapped everything out of the late model into an early model, I've had to splice in the ignition wire from the c104 for switched power and can confirm I get voltage.
      I also spliced in a constant 12v source to pin 18 of the dme plug as stated in the original post.. this splice is done after the main Relay, between the relay and dme. To clarify this means my dme is not receiving the 12V from the main relay like it would usually, but since I T spliced a power source to the wire, power should run up and down the whole line.
      • the imitator
        • May 2013
        • 1006
        #213
        On the battery still at 12.22 I am only getting a readout out of dme pin 27 of around 8.03 hmm. thats out of the ignition wire from under the glove box..
        wow just checking right now, I just bought a new main relay, Now the green ignition wire coming from the glove box, AND just the green wire itself have power? To add to the confusion, when I put the new relay in, it turns my car into the "on" position and my dash board lights up. Only when removing the main relay does it shut down completely.
        Needless to say, getting a constant out Green wire 27 AND the Ignition wire under the dash.
        Main relay lights everything up until pulled, That being said When I insert the relay, I hear the unloader relay (K7) gate engage. hmmm.
        additionally I will take pictures of a 3 prong connector, white in color with a green/purple, red/blue, and Brown ground wire going from the dme to this 3 prong connector about 6 inches up the harness.
        • Bullhead
          • Sep 2014
          • 532
          #214
          Any updates? Great thread too btw.
          sigpic87 325E The Honey Badger
          • the imitator
            • May 2013
            • 1006
            #215
            It's been raining quite hard the past few days, so ive been focusing on other items.
            I think I've solved all my leaks around the firewall and found out the channels leading to the drains were packed with pine needles which was causing water to seep between the blower motor seal and the firewall itself.
            Took out the stock antenna and plugged the hole. I also installed the euro grills and black kidney grills, and now I almost want black trim, the Delphin metallic and black looks nice to me, but my wheels are silver, and I'm not very convinced with painting the diving boards, but perhaps in combination with a minor tuck it would look okay.
            Currently I'm laying down some cheap frost king for minor dampening and insulation purposes, then in with the new carpet. The frostking is very user friendly, and I personally feel it will do a great job.
            • G-Man the Visionary
              • Apr 2013
              • 543
              #216
              Glad to see an update. Been wondering how you're doing. Probably starting to get cold up there, hope you have a heater...
              Streetable poly mounts, trans mounts are here!
              http://www.r3vlimited.com/board/show...ght=streetable
              '94 318i
              '07 335i
              '11 X5
              '89 325ic m30b35
              • the imitator
                • May 2013
                • 1006
                #217
                little nippy, but tomorrow and the next day look good.
                  • Apr 2013
                  • 543
                  #218
                  sup
                  '94 318i
                  '07 335i
                  '11 X5
                  '89 325ic m30b35
                  • the imitator
                    • May 2013
                    • 1006
                    #219
                    sigh... ive been so busy with life. I've been making myself satisfied by doing small projects to the e30 before I leave in the early December.
                      • Apr 2013
                      • 543
                      #220
                      So close, yet so far. You've got a ton invested in this beast, git r dun! Si se puede!
                      '94 318i
                      '07 335i
                      '11 X5
                      '89 325ic m30b35
                      • the imitator
                        • May 2013
                        • 1006
                        #221
                        Well I have a bit of an update.
                        Do to the massive amount of rain in California we are being called down for work. We are leaving Wednesday which means I needed to find a place to store my car.
                        Not only was I offered a place to store it, these fellas who have kindly offered such space have also offered to also finish the swap for me!
                        sa yall can go home now..
                        • Mr. Burns
                          • Aug 2011
                          • 3516
                          #222
                          What in the what?! Who are these angels fallen from heaven?
                          • marshallnoise
                            • Sep 2013
                            • 3148
                            #223
                            Holy balls.
                            Sent from my SAMSUNG-SGH-I337 using Tapatalk
                            Si vis pacem, para bellum.
                            New Hawtness: 1995 540i/6 Claptrap
                            Defunct too: Cirrusblau m30 Project
                            Defunct (sold): Alta Vista
                            79 Bronco SHTF Build
                            • Bearmw
                              • 1323
                              #224
                              I hope you trust their work.
                              • the imitator
                                • May 2013
                                • 1006
                                #225
                                Haha, i said something along those lines too! These fellas have 4 e30s and just finished their 3rd m50 swap and one gentlemen in particular has an e30 M30 project he's boosting. I throughly believe these guys know what's going on with no doubt. None of them are forums members or show goers, just a few guys that dig the e30 platform.
