Save rev range for the M30 with mods
  • Bimmer_man
    • Jan 2013
    • 1477
    Sorry for starting another thread but the other one was getting confusing.
    I have a M30B35 that was out of a 91 735i and i am replacing the pistons with CP pistons. The head work will be done by BimmerHeads. I will have a Miller MAF/W.A.R. conversion on it. Free Flow exhaust, and a ported intake and throttle body. I am hoping to make 250hp but ill dyno it when im done and its in the car.
    But what i want to do is ask to see if revving the engine to 8000 with all of those modifications to it would be safe. this engine will not see 8000 on a regular basis it is not a race car. But every now and then my friends and i do want to go to a track maybe once or twice every other month. Note: they all have old muscle cars so lol. Please if you have real experiance with these engines with similar specs let me know if 8000 is safe. if not let me know what you think the revs should be at. This is my first build and will take a while for me to complete. I just dont want to destroy it.
    Float like a cadillac sting like a Bimmer!:)
  • LJ851
    • 7919
    No.
    Lorin
    The M30 is God's engine.
    • dannyyisntt
      • 3141
      Originally posted by LJ851
      No.
      No.
      • fronton
        • Oct 2009
        • 1262
        I'd try to shift by 6,500 and never past 7,000. Even a S38 shouldn't be revved past 7,000 on a regular basis.
        • navytapaul
          • 615
          why would you want to rev that high anyways? m30's run out of breath way before then...
          • walinsky
            • 16
            NA standard M30B35 max torque @4100RPM / max hp @5650RPM
            add a Schrick cam: max torque @4200RPM / max hp @5750RPM
            Name me one good reason to rev this engine to 8000 rpm.
            I have no clue what headwork BimmerHeads is going to do - if it doesn't involve adding another cam and 12 valves I think you'll have some serious breathing problems even revving over 7k.
            • LJ851
              • 7919
              At 8k a M30 crank looks like this:
              Lorin
              • Bimmer_man
                • Jan 2013
                • 1477
                Well Alrighty then keeping the stock Rev limiter is good then thanks guys for the helpful input.
                • Good & Tight
                  • Apr 2004
                  • 2057
                  If you have the right cam and rockers yes, but for a stock engine no.
                  Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                  ____________________________
                  E-mail Panayiotisx2@gmail.com
                  Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                  • Bimmer_man
                    • Jan 2013
                    • 1477
                    The engine won't be stock. It's gonna have bimmer heads. Head work and new pistons
                    • Doughnut
                      • Oct 2007
                      • 869
                      But for the most part the bottom end is stock right?
                      Stock crank, rods, main, and big end bearings, stock oil pump etc?
                      ///Monstrosity. (OO≡≡[][]≡≡OO)
                      Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
                      • Bimmer_man
                        • Jan 2013
                        • 1477
                        I'm going to be getting VACs performance coated bearings for the crank and rods and the rods are going to stay stock the oil pump a new gear from VAC. But other than that to bottom end will be about the same
                        • Good & Tight
                          • Apr 2004
                          • 2057
                          It's a stock engine stock compression so it's deff a no on the 8k rpm especially with a stock cam.
                          • Bimmer_man
                            • Jan 2013
                            • 1477
                            That's stuff won't be stock here is what the engine will have
                            Port +polish head
                            HD rocker arms
                            Rocker lockers
                            285 degree cam
                            1mm over sized valves
                            Ported intake manifold
                            Oversized throttle body
                            Bigger piston bore
                            10.0:1 compression ratio with cp pistons
                            Performance coated bearings
                            Miller maf/W.A.R. Chip conversion
                            Light weight flywheel
                            That is what I will be getting for the engine.
                            • walinsky
                              • 16
                              ... and which part of 'no' you didn't understand exactly?
                              [subscribed]
                              Don't tell me you're going to be notching the subframe as well...
                              *pissing my pants already*
