Save rev range for the M30 with mods
  • Komzorz
    • Jun 2011
    • 332
    You'd probably need an entirely new forged / blueprinted / dynamic balanced bottom end to safely turn those kinds of speeds, and even then I don't think the head will flow enough to support actually making 8k rpm worth it.
    '87 325is - Schwarz/Schwarz
    • Good & Tight
      • Apr 2004
      • 2057
      Is your 285 cam custom made to make power at 8k? and will you be running headers and aftermarket harmonic balancer? (didn't see it on the list)?
      Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
      ____________________________
      E-mail Panayiotisx2@gmail.com
      Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
      • Bimmer_man
        • Jan 2013
        • 1478
        Headers yes aftermarket harmonic Ballenger I haven't even any so no but if there is a better one out there I'd consider it. But I don't think I'll take this engine to 8k
        Float like a cadillac sting like a Bimmer!:)
        • reno808
          • Oct 2013
          • 4
          Originally posted by Titan_Omega
          That's stuff won't be stock here is what the engine will have
          Port +polish head
          HD rocker arms
          Rocker lockers
          285 degree cam
          1mm over sized valves
          Ported intake manifold
          Oversized throttle body
          Bigger piston bore
          10.0:1 compression ratio with cp pistons
          Performance coated bearings
          Miller maf/W.A.R. Chip conversion
          Light weight flywheel
          That is what I will be getting for the engine.
          Ummmmmmmmmmmmmmmmmmm stock
          • stinkydriverx
            • Jan 2008
            • 501
            junkyard m30, head studs, gasket set, turbo. twice the power.
            In before" I like the NA response on my 3.5 liter inline 6"
            Turbo m30 drift car build.
            500whp or bust.
            http://www.r3vlimited.com/board/showthread.php?t=256525
