The m30 with Getrag 240 thread
This is a sticky topic.
  • SketchyRex
    • Feb 2012
    • 242
    #91
    Has anyone swapped over to the bigger e34 trans?
    If so, how much more did the firewall have to be banged in?
    • lukeADE335i
      • Apr 2013
      • 1386
      #92
      I'd say close to an inch if you still want to be able to get to the bolts at the top of the gearbox and you're engine is in P3 (assuming with the G240 you didn't bang the firewall already).
      HoofensteinHD found a great option from RHD engineering for the G240 - lightweight M10 flywheel that is built to use a stock 228mm M20 clutch kit. Initial setup would be similar in cost to sourcing a stock M10 flywheel and HD 215mm clutch, but you'd have cheap clutch kits for the life of the car :)
      My e30: OEM+ with M30B35
      • marshallnoise
        • Sep 2013
        • 3148
        #93
        http://racehead.com.au/products-page...-flywheel-m10/
        Or you can get the one I am selling! OEM m10 2002tii flywheel. 228mm. Shameless plug
        Si vis pacem, para bellum.
        New Hawtness: 1995 540i/6 Claptrap
        Defunct too: Cirrusblau m30 Project
        Defunct (sold): Alta Vista
        79 Bronco SHTF Build
        • totheredline
          • Jun 2013
          • 762
          #94
          Quick question guys. I recently got a great deal on a low mileage Getrag 265/6 (US M3 trans with the detachable bellhousing) , pretty much the best transmission next to the 265/5 dogleg box.
          I was originally going to use a getrag 240 with e30 318i flywheel so I bought an upgraded clutch for it. That being said. Can I use the throwout bearing I got with the clutch kit or do a need one that's "taller" for the 265 bellhousing?? Thanks in advance.
          = Heidi 1988 325 -> 335i. 7200rpm built M30
          • Van31
            • May 2013
            • 10
            #95
            Sorry to bump a really old thread, but I'm getting mixed ideas on the driveshaft to use, 320i manual, and 325i manual I've heard can work apparently.
            • e30m3s54turbo
              • Jun 2010
              • 3265
              #96
              If you have a 318i m10 1.8 motor answer is no for 325i m20. If your 320i is a m20 b20 is yes.....
              • lukeADE335i
                • Apr 2013
                • 1386
                #97
                Since he's posted in the M30/G240 thread, I presume he's referring to an M30?
                In position 3, the 320i drive shaft is the one to use.
                You can use a 325i at a pinch, but you need to extend the driveshaft on the spines, and mount the centre bearing further forward than the standard location to get some preload on it.
                I'm running a 323i driveshaft, and this was what I had to do.
                If you want to see a bunch of different BMW driveshafts side by side, check pg. 3 of this thread.
                • e21jps
                  • Aug 2011
                  • 44
                  #98
                  sorry to haul up an ond thread but im trying to find out abou the 2 different ring gear pitches of m20 FW! almost all m20 FW have fine pitch 137 teeth but do some have a different tooth count???
                  For info here is the complete run-down on all interchangeability and fitment! We make FW so i have a lot of info about the differences.
                  There are only 2 different fitments big block m10/m30/s14/s38 etc they all have the same Fw ring gear with 116 teeth and are all interchangeable, as are the gearboxes and starters.
                  Then there are the small blocks starting at m20, then m40 right through to m54 (and maybe beyond!) they all have the same pinion to crank dimension and ring gear offset and are all interchangeable as are all the gearboxes and starters BUTT!!!>>>>>
                  The m20 has a unique tooth count of 137 teeth and a fine pitch starter pinion to match where as ALL the others only have 113 teeth, SO as long as you match m20 starter to m20FW or match any m40,42,43,44,50,52,54 starter to any m40....54 FW then they are all interchangeable on all small block engines.
                  you can NOT interchange small block and big block FW!!
                  I sell ITB's and performance parts www.racehead.com.au
                  e21 race car m20 power! 293Whp atmo 2.9
                  details here http://e21jps.webs.com
                  drive by video http://www.youtube.com/watch?v=kOdPbErYlho
                  incar race http://www.youtube.com/watch?v=sbr0ZCmjsYM
                  incar video http://www.youtube.com/watch?v=aQyvDR-B00A
                  drag racing http://www.youtube.com/watch?v=7XmznH6PND4
                  • Shftr8
                    • Aug 2014
                    • 530
                    #99
                    Anyone else running the 318ti driveshaft? Someone touched on the subject that it can work but didn't really go any further then that
                    • st.petebiodiesel
                      • Jul 2015
                      • 211
                      #100
                      Thought I’d add my info.
                      -E30.DE Engine mounts in furthest back position.
                      - Getrag G240 from 85 318i.
                      - 88 325i driveshaft with 1.75” of spline showing.
                      My trans ended up being bad so I swapped the internals and rear case from a M42 G240 from a 91 318is.
                      They are both exactly the same trans the only difference is the front case bell housing.
                      Good info to know since it’s easier to find M42 G240s than M10 G240s.
                      • glnr13
                        • 1334
                        #101
                        Very interesting...
                        • MiWision
                          • Mar 2018
                          • 17
                          #102
                          This is our setup:
                          E30 320i 4-door with Motronic 1.3
                          5-speed M10-gearbox
                          Lightened 228mm M10-flywheel from RHD (3.2 kg)
                          S14 228mm clutch
                          Sachs 618 M20 pressure plate
                          E30 320i M20 prop
                          E30 320i gear linkage
                          Selfmade engine mounts
                          M20 harness
                          Headers from S38 3.6
                          Fun fun fun!
                          • lukeADE335i
                            • Apr 2013
                            • 1386
                            #103
                            Nice! Engine looks very neat there.
                            • Jaxx_
                              • Dec 2009
                              • 1880
                              #104
                              I'm about to pull my G240 behind my M10 for a G260 and I was curious about weight differences.
                              (using a bathroom scale)
                              G260/6 (e34 donor): 81lbs
                              Driveshaft, big guibo: ~17lbs
                              G240: 62lbs
                              318i Driveshaft: ~17lbs
                              So it looks like a difference of about 20 lbs between the 240 and 260 all-in.
