Brake Booster for S38 Throttle body on M30
  • Bimmer_man
    • Jan 2013
    • 1478
    I will be getting a S38 intake on my M30. Yes i know the cost and i still want to do it. I will be ordering the throttle bodies here in the next couple of months. And what i need to know is What brake booster i should run. Im asking because I will be making my own air box so i dont need spacers or anything to close my hood. There isnt much room to work with the stock booster. I will be modifying my fire wall to sit the M30 in the furthest back position. Any insight will be useful. I do not want to go Boosterless so please dont suggest that. If i could i would like to use these intakes if i have the funds for them.
    Note: My set up will be with megasquirt running alpha-N
    Float like a cadillac sting like a Bimmer!:)
  • fronton
    • Oct 2009
    • 1262
    If you are making your own intake, just form it to fit around a iX/M5/735 booster. If you want even small diameter you can use a geo metro or VW polo booster but I'm not sure how the clevis lengths and design match up with the e30 brake pedal.
    What is the purpose of the picture you posted? Is your m30 in a e28?
    • Bimmer_man
      • Jan 2013
      • 1478
      the purpose was just to show the intake i may get if i have the funds to get it. hoping someone has seen that in a car and give me some insight as to how it would work in an E30.
      • fronton
        • Oct 2009
        • 1262
        The booster you need will depend on whether you are making your own plenum or buying an aftermarket one designed to fit e30 applications (maxx's cf intake). Treehouse made a small booster for 24v swaps but it isn't cheap and I'm not sure its even available anymore. You'll have to remotely locate the brake fluid reservoir as well if you haven't already.
        • JOMARO
          • Mar 2006
          • 116
          dont go for the polo one , unless u like to literally stand on the brake pedal
          ask me how I know
          • Bimmer_man
            • Jan 2013
            • 1478
            i figured i would have to do that i havent relocated it yet. and yeah they dont make them anymore.
            • e30m3s54turbo
              • Jun 2010
              • 3291
              Trevor, you should take fronton advice ix/m5/735 booster. It will give you a little more room. It is a nice up grade. Hartge H35-24 swaps would notch out the m88 and s38 intakes to fit around the e30 brake booster. If you don't want use the m88 or s38 intake. Make sure you make it out of aluminum. In case you ever want to boost.
              • Jb325is
                • 2137
                You're going to need a lot more room, so go for the smallest booster you can find. I couldn't even get the stock velocity stack on #6 cylinder on mine without hitting.
                - '88 m54 coupe
                <3
                • Bimmer_man
                  • Jan 2013
                  • 1478
                  yeah ill do that and i never want to boost this E30, I do however want a iX and boost that. But one project at a time for me and my wallet.
                  • e30m3s54turbo
                    • Jun 2010
                    • 3291
                    On my m88 swap I have no spacer and sits in position 3. Hartge made H35-24 oil pan for the e30. It allowed to lower motor in engine bay. My intake does not touch the hood. Stack #6 did hit e30 booster. I copied what Hartge did notch it. The next thing you are going to run into is you thermostat. Hartge built a H5sp m30 with M5 itbs and Hartge custom thermostat. Rav is doing the samething to his car. Here is a link.
                    • e30m3s54turbo
                      • Jun 2010
                      • 3291
                      I found this E30 Zone Forum from UK. Sorry about the big pics.
                      • Bimmer_man
                        • Jan 2013
                        • 1478
                        Big pics are fine makes it easier to see what's going on
                        • Alpina
                          • Oct 2004
                          • 838
                          Howdy sir,, and happy new year
                          I was running S38B38,, and i used E34 M5 booster+ master,,
                          imo the best result out there........
                          Sveinbjörn Hrafnsson
                          E30 CABRIO V12 M70B50 ///
                          ALPINA B10 BITURBO 346 @ 507
                          E34 550 V12 JML
                          Finnish wisdom : If you want to Win,, hire a Finn
                          http://alpina.123.is/pictures/
                          • wannaBMthree
                            • Apr 2007
                            • 601
                            Lovely, can't wait to do that someday
                            • Alpina
                              • Oct 2004
                              • 838
                              Hello again,,
                              Here is the newest solution,, and maybe the best so far
                              This is a brakebooster from a toyota HILUX,, 4wd,, i am not sure about year etc etc ,, but will find out if needed,,
                              As you can see this is a S50 Euro swap,, and there is a lot less space with S50 EURO vs S38,, because of the shape of the intake manifold,,
                              E34 550 V12 JML
