Brake Booster for S38 Throttle body on M30
  • digger
    • Nov 2005
    • 6215
    what diameter are these boosters compared to stock one? how much extra room is there?
    • Alpina
      • Oct 2004
      • 838
      In my case with the E34 M5 booster,, i made a square hole in the firewall and pulled the booster about 1/2 " or 10 mm to the left to be SURE the intake manifold would not touch the booster,, but this HILUX booster is a lot smaller vs the M5 booster so that is ,,i think,, i very good solution
      Sveinbjörn Hrafnsson
      E30 CABRIO V12 M70B50 ///
      ALPINA B10 BITURBO 346 @ 507
      E34 550 V12 JML
      Finnish wisdom : If you want to Win,, hire a Finn
      http://alpina.123.is/pictures/
      • digger
        • Nov 2005
        • 6215
        surely the smaller booster reduces the assist dramatically being a cross sectional area thing (diameter^2)?
        • navytapaul
          • 615
          http://www.extrudabody.com/servlet/t...7s-with/Detail
          anybody seen these before?
          • wannaBMthree
            • Apr 2007
            • 601
            Originally posted by navytapaul
            No, but badass!
            I know there is some guy on e30tech making them for the M20.
            • navytapaul
              • 615
              was there ever a solution to the booster problem for this? Does the Hilux booster work or is the e34 m5 booster+master the answer?
              • F34R
                sLaughter
                • 12376
                What management are you planning to use?
                Instagram: @BWeissLeather
                Current cars:
                ~ '87 325 M30B35 swap
                ~ '87 535
                ~ 01 540 Msport 6spd
                ~ '06 X5 4.8is
                • garagistic
                  • Apr 2011
                  • 1712
                  What about going boosterless? Wilwood reverse mount pedals with mastercylinders under the dash? Our boosterless setup works well for our v8 customers.
                  Although pedal will be stiffer it will not be unmanageable when used with small master cylinders (they compensate for being unboosted).
                  • navytapaul
                    • 615
                    If I was going to do this, I'd go MS for sure. Seems like the most suitable choice to me. Only reason I ask about the booster is because Hartge got it to work, so why can't we?
                    Sent from my SAMSUNG-SGH-I727 using Tapatalk
                    • e30m3s54turbo
                      • Jun 2010
                      • 3295
                      Hartge never changed the e30 brake booster. Hartge modified the s38 intake. Also Hartge had special adjustable motor mounts and a 9 quart oil pan and oil pump. That is how Hartge could make the s38 fit in the e30. Hartge never used sub frame spacers.
                      Trevor, any up dates? I have a feeling you are going to have your itbs done before me.
                      • navytapaul
                        • 615
                        Interesting, did not know that's how they made it work. Do you have any more info on how the setup works? I want to do the same thing on my m30.
                        • Bearmw
                          • 1323
                          9 quart oil pan? Wow
                          • kylelauffer
                            • Dec 2009
                            • 624
                            more info on this? to me those pics look like it gives alot of room with that booster.i wonder if an m60 would squeeze by that booster hah.
                            Hello again,,
                            Here is the newest solution,, and maybe the best so far
                            This is a brakebooster from a toyota HILUX,, 4wd,, i am not sure about year etc etc ,, but will find out if needed,,
                            As you can see this is a S50 Euro swap,, and there is a lot less space with S50 EURO vs S38,, because of the shape of the intake manifold,,
