Im starting my M30 Swap.
  • navytapaul
    • 615
    #31
    I'm using those too, in position 2, and there's no way to fit anything in there. I'd love a puller if it would fit.
    Sent from my SAMSUNG-SGH-I727 using Tapatalk
    • LagunaSecaBlue
      • Sep 2013
      • 360
      #32
      I'm running position 3 mounts. A 324td mech fan fits and a slim electric will definitely. I NEED the maximum amount of cooling I can get. When Phoenix hits 120 in the summer and I got A/C running its going to be a huge headache. But in better news I found my M30B35!
      #AZE30
      1991 318i
      1989 325i
      1989 335i
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        #33
        Nice! I think you'll be able to make it work then. Just remember to make up a good shroud or the puller fan will be useless!
        • LagunaSecaBlue
          • Sep 2013
          • 360
          #34
          Im going to use the E28 one or fab one up.
          #AZE30
          1991 318i
          1989 325i
          1989 335i
          • navytapaul
            • 615
            #35
            This should be interesting then, I haven't actually seen anyone use the slim fan with a shroud. Its gets pretty hot here in tx too
            • LagunaSecaBlue
              • Sep 2013
              • 360
              #36
              I have to have the best cooling I can get with this build. So I will be doing whatever I can.
              #AZE30
              1991 318i
              1989 325i
              1989 335i
              • the imitator
                • May 2013
                • 1006
                #37
                You can run megasquirt and have a delete plate up front + position 3.. That would give you amazing amounts of room. Thicker radiator, push n pull.
                • Bearmw
                  • 1323
                  #38
                  The Imitator is right on and not to be imitated.
                  • Doughnut
                    • Oct 2007
                    • 869
                    #39
                    Isn't the pulley too high up on the m30 to run a mech. fan?
                    You would have to shave the blades right down so it wouldn't hit under the bonnet..
                    I could be wrong though.
                    ///Monstrosity. (OO≡≡[][]≡≡OO)
                    Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
                    • LagunaSecaBlue
                      • Sep 2013
                      • 360
                      #40
                      Only way to make it work is with a 324td mech fan and clutch.
                      #AZE30
                      1991 318i
                      1989 325i
                      1989 335i
                      • LagunaSecaBlue
                        • Sep 2013
                        • 360
                        #41
                        So I am using my M20 harness and it looks like the M30 harness doesnt have a disconnect to the fuel injector harness like the M20. So do I need to go pull one off a M20 intake mani? Also do I need to order a Manual TPS or do I need to order a whole new Throttle Body since they need to calibrated?(Since the Auto harness connecter is different than the Manual connector)
                        #AZE30
                        1991 318i
                        1989 325i
                        1989 335i
                        • navytapaul
                          • 615
                          #42
                          You need to use the whole m20 harness. If you didn't get the injector harness, its not complete. For the m20 tps, they are all the same for auto and manual and will swap over to the m30 throttle body. Only variant is the late autos with the selector knob on the center console.
                          • LagunaSecaBlue
                            • Sep 2013
                            • 360
                            #43
                            Yeah, I will have to buy another injector harness, sold mine with the intake mani. So just find a manual TPS and pop it in? Isn't the TPS calibrated with the Throttle Body itself?
                            #AZE30
                            1991 318i
                            1989 325i
                            1989 335i
                            • navytapaul
                              • 615
                              #44
                              Yeah, any e30 tps will work on an m30 throttle body. They are very easy to adjust, you should hear the tps click as soon as you open the butterfly. Just to clarify, any harness from an i motor will work on an m30. I'd source an injector harness like you said, and you'll be in business.
                              • lukeADE335i
                                • Apr 2013
                                • 1389
                                #45
                                I'll be really interested in seeing your setup with the 324td fan when it's done. My engine is also in P3, and if I could run one I would as unlike most people doing fan deletes, I'd rather the clutch fan.
                                Just to put your mind at ease, we had a week last week where the temperature was 110 all week, and my car had no overheating issues just running the stock e32 pusher fan. Mind you I don't have air conditioning so I was pretty over heated ;)
                                My e30: OEM+ with M30B35
