Im starting my M30 Swap.
  • LagunaSecaBlue
    • Sep 2013
    • 360
    So I am selling my M20 out of my 89 325i.
    PnP Parts list...
    M30B35 engine
    Getrag 260/5(Hopefully 6)
    E28 535i Radiator
    M30 ECU Chip
    What am I missing, my local PnP is having a 50% off day coming up soon.
    #AZE30
    1991 318i
    1989 325i
    1989 335i
  • uturn
    • Dec 2010
    • 1008
    A 3.46 LSD, 4.10 will make 1st gear useless and 2.93 will leave you wanting.
    • G-Man the Visionary
      • Apr 2013
      • 543
      decide what you're gonna do with the cooling system... I think ppl have a hard time with the firewall mounted overflow res... may want to get an extra hose to cut up and modify to fit the stock e30 res...
      Streetable poly mounts, trans mounts are here!
      http://www.r3vlimited.com/board/show...ght=streetable
      '94 318i
      '07 335i
      '11 X5
      '89 325ic m30b35
      • navytapaul
        • 615
        2.93 is great for the highway, pretty docile around town though.
        Sent from my SAMSUNG-SGH-I727 using Tapatalk
        • LagunaSecaBlue
          • Sep 2013
          • 360
          I have a 3.73 LSD. Also can I keep the A/C? I hear the I will run into overheating issues so is this swap dead in the water for me? It gets REALLY hot here in the summer. In stop and go traffic I could easily hit 115 degrees ambient temperature outside in the dead of summer.
          #AZE30
          1991 318i
          1989 325i
          1989 335i
          • lukeADE335i
            • Apr 2013
            • 1389
            I run my M30 swap without AC, and I have no overheating issues. I drove in 110 degrees two days ago (or 43 degrees... we're metric down here!!), and have sat in traffic in the past in 115 - 118 without issues. I run a 16 inch e32 pusher fan + Behr e28 535i radiator.
            I don't see why you'd have too many issues with AC fitted + an appropriate fan.
            I also run a 3.73 diff - lots on fun in city driving :) & fine on the highway, although I'm probably sacrificing some fuel economy.
            As G-Man suggested - you'll want to reuse your overflow reservoir, and chop up some e34 & e30 hoses to make it work.
            Easiest way to get together a comprehensive list is to have a read of Frank's guide (stickied at the top of the M30 & other swaps forum). I didn't do this when I did my swap, but it would have saved a lot of time / research.
            My e30: OEM+ with M30B35
            • LagunaSecaBlue
              • Sep 2013
              • 360
              I am trading my M20 with another member on the forums who is local for his M30.
              Couple of questions or matter of opinions...
              1. Which Driveshaft and Transmission(I currently have a 325i Late Model Manual Driveshaft Rebuilt by Portland Driveshaft)
              2. Use the M20 Loom or M30 Loom?
              3. I want a late model M30, correct? C101 is a direct fit?(Besides a couple rewires for Blower/Windows) Oil Pan fits.
              4. Replace entire ECU or just the Chip?
              5. Which motor mount position? I am running A/C. Want best Weight Distribution(Does Position 3 work?)
              6. Cooling options? I want this car as cool as possible. Just get a Electric Puller or also replace the Aux Fan with a better one?
              Thank you.
              #AZE30
              1991 318i
              1989 325i
              1989 335i
              • Bimmer_man
                • Jan 2013
                • 1478
                Im doing this swap as well and here is what i am doing
                Custom single piece drive shaft
                Usng a late model M20B25 harness
                the best M30 according to paul burk ( M30 GOD ) a 86 M30B34
                Im getting Megasquirt but a stock ECU for the M30 is fine
                im keeping my AC and powersteering and im using position 3 you will need to modify the fire wall
                Im not sure what im doing with this one yet
                Again this is what im doing you can do something else but thats what ive come up with
                Float like a cadillac sting like a Bimmer!:)
                • navytapaul
                  • 615
                  1. depends on transmission, if you have a g260, you can use the front half of and e28 and back half of an e30. If you go with a g265, you're going to have to shorten it about 2"
                  2. m20 is cleaner and doesn't have to be repinned, just get the plastics from the m30 harness and swap everything over.
                  3. Yes, but as I said above, the m20 harness works and doesn't have to be repinned. e32/e34 pans will fit and have correct pick up.
                  4. Entire ecu needs to be replaced. Even though they are both 1.3, the 179 ecu is different. Get a 179 ecu + chip and it will keep you happy for a while.
                  5. position 2 works the best, and requires the least massaging of the firewall. Position 3 is really far back and isn't needed for a/c.
                  6. Electric pusher works for me down here in Texas. Puller won't work in pos. 2 so yes, just replace the aux fan with moar cfm's.
                  • kronus
                    • Apr 2008
                    • 13032
                    the m20 and m30 getrag 260s are both the same length, but m30 one has the big giubo that also came on the 87 eta. you can swap transmission flanges from big to small and vice versa to accommodate a stock e30 manual driveshaft.
                    get a b35, it's better and already is set up for the sensors you need for a late model e30 harness. they mostly came with front-sump oil pumps, but some did come in 88-89 e24s which had mid-sump pans. you want the front-sump one.
                    cars beep boop
                    • navytapaul
                      • 615
                      m20 and m30 g260's have different bellhousings as well so they aren't interchangeable
                      • CorvallisBMW
                        Long Schlong Longhammer
                        • 13039
                        You can run A/C but you'll need the biggest (highest CFM) pusher you can find plus a small puller on the backside of the radiator near the alternator (10" wil fit). Make sure you wire it up to a low temp switch AND a manual override switch just in case.
                        Also don't forget you'll need e34 535i downpipes to clear the subframe and control arm bushings,
                        • LagunaSecaBlue
                          • Sep 2013
                          • 360
                          Let me run this setup by you guys.
                          Late model E34/32 M30B35
                          Position 3 Mounts
                          Late model M20B25 Harness
                          Late model E34/32 Getrag 260
                          My E30 Rebuilt Manual Driveshaft(If I can)
                          E28 Radiator
                          Electric Fan
                          Upgraded Spal Pusher Aux Fan with the 80/88c switch
                          75 Degree Thermostat
                          Pull the ECU out of a E32/34
                          I want to run Position 3 mounts. I am planning on running the E34/32 Getrag 260 with a E30 Getrag 260 Output flange, can I still us my manual E30 Driveshaft? Who should I get my mounts from?
                          Any tips on a budget build?
                          #AZE30
                          1991 318i
                          1989 325i
                          1989 335i
                          • kronus
                            • Apr 2008
                            • 13032
                            you will need a small trans output flange and a lock ring to run that driveshaft.
                            you will also not be able to fit a mechanical fan, don't bother. It sits too high on the engine and hits the hood, even if you have room to the rad to fit it.
                            position 3 will be difficult. you will need more work to get the downpipes around the firewall, and general rear-of-engine maintenance will be inconvenient.
                            everything else is spot on
                            cars beep boop
                            • LagunaSecaBlue
                              • Sep 2013
                              • 360
                              Okay, Ill run an electric.
                              What are the exact benefits and disadvantages of Position 2 vs 3?
                              I am just pushing for position 3 mostly because of http://www.e30.de/335i/06.htm
                              #AZE30
                              1991 318i
                              1989 325i
                              1989 335i
