M30 firewall modification pics
  • Denny
    • Jan 2010
    • 822
    Denny
    ___________
    1990 BMW red 325IC M30B35 all stock Girlfriends ride
    1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
    Blogs:
    http://bmw325e30.blogspot.com/ (restoration)
    http://bmw325e30turbo.blogspot.com (Twincharge M20)
    http://bmw325e30m62b44.blogspot.ca/
    • SketchyRex
      • Feb 2012
      • 242
      Much love fellow r3vers.
      • Mr. Burns
        • Aug 2011
        • 3516
        here's mine.
        89 vert.
        peeled off the rubberized sound deadening material and went at it with a 8lbs sledge and ball peen hammer.
        I plan on recovering it with a thin film of somesort or simply re-shooting it with paint before I put the engine back in permanently.
        Originally posted by flyboyx
        i have watched my dog lick himself off a few times
        • Mr. Burns
          • Aug 2011
          • 3516
          Originally posted by TimeMachinE30
          Good call. I've read no tweaking. I've read it depends on what position.
          I thought this too.
          I'm using Garagistic mounts, and there is absolutely no way it will fit without any hammering.
          I tried.
          many times.
          • Mr. Burns
            • Aug 2011
            • 3516
            Originally posted by ultimateracing335i
            Do you guys run AC?
            I tried to drop the engine with the AC on, and the pulley simply couldn't clear.
            took the whole deal off and went in smoothly
            • slammin.e28
              שמע ישראל
              • 12054
              Fuck AC haha. Btw you won't be able to install the motor with the AC compressor on if you plan on running it. Some have troubles getting the motor in with just the power steering pump. There really isn't any room to run AC with these swaps.
              Challenge accepted.
              • Bearmw
                • 1323
                I didn't need to modify the driver's side firewall at all but pushed in the passenger side a lot both behind the head and below it as well to create plenty of clearance for long tube headers. I used Otis B35 mounts in the furthest back of the two mounting holes. I ended up removing the insulation from the cowl cover and I covered the modified firewall area with stick on shiny aluminum faced heat shield that is thinner than the factory sound deadening. I have a good amount of clearance with this setup but I'm not running A/C or a turbo.
                • lukeADE335i
                  • Apr 2013
                  • 1386
                  Running e30.de mounts in P3, I only needed the most minor of mods with the B35. The engine dropped in with just the bulkhead insulation removed, and then I gave it a small hit near the starter where it barely touched. Then I pushed the bulkhead back with a bar about 3mm for clearance at the back of the head.
                  I an running the Getrag 240 box though, which might make a difference for gearbox clearance - the 240 is tiny.
                  If you happen to bash the firewall on a RHD car just remember that there's a long brake linkage to think about back there too!
                  My e30: OEM+ with M30B35
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    Challenge accepted.
                    Lol. Don't you need a e30 to accept a challenge
                    1991 318i 4dr slick top
                    Mtech 2 turbo restoration
                    • glnr13
                      • 1334
                      garagistic mounts, position 3. pounded about an inch on the passenger side to clear the head.
                      also, I dremeled the intake manifold a wee bit to clear the brake booster. before i did this i couldn't get the motor mounts to seat flush.
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        I make my own rules.
                        • CorvallisBMW
                          Long Schlong Longhammer
                          • 13039
                          Originally posted by Wishno87
                          Do any decent pics exist? I have been on this site for quite a while and have never seen any. I am in the middle of an M30 swap and would like to see some. Post'em if you got'em
                          I don't have any pictures, but I didn't have to massage mine more than about 3/4" or so with the Good & Tight mounts.
                          Do you guys run AC?
                          I do, been running it since day 1. Works perfect.
                          There is plenty of room if you're in "position 3" or whatever it's called. Basically if you have to massage your firewall in order to get the engine sat far enough back to match up with your mounts, then you'll have enough room for the AC compressor. Leave the compressor, lines, condenser, dryer, etc all hooked up when you remove the old engine. Just unbolt the compressor and tie it out of the way. When you install the m30, you'll have to modify the compressor bracket a bit but otherwise the compressor will bolt right up to your new engine.
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            Lolololol
                            • Benjamin_Button
                              • Mar 2014
                              • 384
                              It's possible to run ac with m30 swap? Interest suddenly piqued.
                              ~Stay Thirsty~
                              • ThatOneEuroE30
                                • Dec 2013
                                • 8626
                                Read two post up
