CorvallisBMW, what is easier, retrofit my m10 ac comp with a different bracket on the engine or convert to r134
M30 firewall modification pics
I don't know what's involved with the m10, as I started with an m20. My guess is that the lines might be a bit too short as the m30 will put the AC compressor further towards the front of the car compared to the m10.
Retrofitting to r134a isn't hard, but it has nothing to do with engine swaps. The same amount of work is involved no matter what engine you have, as the engine is irrelevant to the type of refrigerant used.
Leave the compressor hooked up until you get the m30 in, and see if it can reach the bracket with the stock hoses. If it doesn't reach, you'll have to open the whole system anyway and swap in m20 hoses, at which point you can also convert to r134a if you want to.
Of course, why wouldn't it be? The m30 is just a bigger m20... everything is the same. Lots of people have kept AC successfully and there are at least half a dozen threads in the m30 section dealing with it.Comment
I ran A/C no problem.
Had to extend the Low side hose as it was too short. (Original motor was an m40)///Monstrosity. (OO≡≡[][]≡≡OO)
Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
i mocked my car up with the m10 compressor on the m30 bracket fine. can't confirm about belt size or hose fitment since i ditched it when I finished the build.sigpicComment
Weird, I had to bang in my wall a good ~.75in in some spots to get my motor to fit my '92 325ic with the garagistic mounts. mine was the early b35 block, IDK if that makes a difference. I slotted the top support on my stock rad and it practically touches the dizzy.'92 335ic Alpinweiss II/IndigoOriginally posted by Japandrew73I'm not going to be "cutting up" the subframe, I'm going to be notching it
'79 323i Arktisblau EuroComment
Got the engine from a 91 535i at a junkyard. Don't know what gen b35 it is. Maybe different from yours I suppose.
Used stock m20 rubber mounts.Comment
