Spark plug wires
  • G-Man the Visionary
    • Apr 2013
    • 543
    Spark plug wires
    Can anyone give some insight or recommendations on the best wires for an M30B35? Might be interested in buying some used if anyone has some good ones. Thank you!
    Streetable poly mounts, trans mounts are here!
    http://www.r3vlimited.com/board/show...ght=streetable
    '94 318i
    '07 335i
    '11 X5
    '89 325ic m30b35
  • Mr. Burns
    • Aug 2011
    • 3516
    the aftermarket BAV auto 8mm 'performance' wire reviews have been spotty at best.
    when I did my research I found that Bosh, Bremi and Beru work just fine.
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
    • curtis_luu
      • Jan 2015
      • 51
      stock wires
      • EatsHondas
        • Sep 2012
        • 404
        I bought Magnecor wires for my ole' M20B25 a few years back and they rock. I will be trying to fit them to my B35 in the next few days, but I'm anticipating they won't be long enough. Extremely good alternative to $$$ stock wires though.
        EDIT: The M20B25 wires are plenty long enough for the M30B35 and fit in the stock spark plug wire loom perfectly. However they have a straight connector for the cap, not a right angle-connector. The M30 cosmetic cover will not fit over the M20 wires because of this.
        1989 325i Lachssilber Sedan
        5-Speed Swapped
        M30B35 Swapped
        MegaSquirt MS3X
        1987 325i Lachssilber Sedan
        260k OEM Automatic Daily Baby
        • Bearmw
          • 1323
          Beru are supposed to be good.
          • totheredline
            • Jun 2013
            • 762
            I got a taylor wire kit. you have to cut them to length and put the boots on but the wires are 9.5mm and only 50 ohms of resistance per ft
            = Heidi 1988 325 -> 335i. 7200rpm built M30
            • lukeADE335i
              • Apr 2013
              • 1389
              Stock is fine (or any of the quality after market suppliers of stock replacement wires). BMW use good wires right from the factory. We're not talking about a GM product here :)
              My e30: OEM+ with M30B35
                • Apr 2013
                • 543
                Thank you all
                '94 318i
                '07 335i
                '11 X5
                '89 325ic m30b35
                  • 37833
                  I've been happy with the Ireland Engineering performance wires on M20's and M30's.
                  Grover Beach, California
                  BimmerHeads.com
