M30 Swap : Which Motor Bushings?
  • TimeMachinE30
    • Jun 2014
    • 3749
    I've been told the 333i used inverted E34 M30 mounts. Anyone go that OEM+ route? Do I go poly? Do I use my existing M20 OEM rubbers?
    Please LMK. Not racecar. Looking for smooth, cruiser.
    ACS S3 Build / Dinan 5 E34
  • e30m3s54turbo
    • Jun 2010
    • 3280
    Contact this guy with a 1984 Alpina 333i.
    • lukeADE335i
      • Apr 2013
      • 1386
      Quality e30 rubber mounts work fine for a stock M30B35.
      My e30: OEM+ with M30B35
      • csermonet47
        • Jul 2009
        • 937
        A guy on here said he used stock 80s V6 Jaguar mounts and he said they are a little shorter than the stock ones and a tougher rubber. I may go this route.
        I have AKG M20 poly mounts (bolt through design, basically a solid mount) and they are pretty bad. A lot of vibration especially when the car is cold. I would like to go rubber but I worry that stock M20 mounts will make the motor hit the hood since I had to shorten my poly mounts to keep the clearance between motor and hood. I have heard stock M20 mounts tear under M30 torque but I think a fair amount of people run them. I have the Otis mounts so clearances may be different with different mounts.
        Alternatively Revshift makes a poly mount that is not bolt through. Each stud is embedded into the poly to help isolate vibrations. I got a guibo from them once and it was garbage so I am not sure if their mounts would be any better.
        Are Three Vee
        Dad Spec
        • TimeMachinE30
          • Jun 2014
          • 3749
          I appreciate it. ^
          Need a roll call of M30 swaps, mount design and position, bushing and satisfaction with the combination.
          I'll run M20s I think for the time. .. and I got a while before I get the motor in.
          • chadthestampede
            • Jul 2008
            • 3601
            I used m20 mounts and they've worked fine for like 7 years.
            Originally posted by LJ851
            Feedback
            • Andy.B
              • Sep 2011
              • 1650
              M30b34+g265
              Q-bang engine mount arms
              80's jag rubber mounts
              E30m3 transmission cross member
              Poly e30m3 transmission mounts
              I ran m20 rubber mounts at first, and while the engine vibration was sufficiently dampened, and the whole assembly well supported, there was too much of a drive line angle causing it to chew up driveshaft giubo's. The jaguar mounts made no noticeable difference in nvh, but lowered the engine about a half an inch.
              • CorvallisBMW
                Long Schlong Longhammer
                • 13039
                I highly recommend the 80A urethane engine mounts from G-Man The Visionary. They provide better mass control under hard braking/cornering but don't transmit any more NVH than stock m20 rubber mounts.
                • TimeMachinE30
                  • Jun 2014
                  • 3749
                  I am in touch with him.. well was, once. He did not respond about having any more in stock.
                  • McGyver
                    • 4634
                    I've got Garagistic engine arms with condor delrin bushings for both the engine and trans. I would like the engine to sit a little further back, but whatever. I got the delrin mounts versus OEM style rubber or polly so that my engine can't move at all and crush my radiator (I only have about 3-4 mm of clearance).
                    The solid bushings transfer ALL of the engine vibration to the frame and you can really feel the car vibrate when driving. It also sorta feels like the car is crashing through bumps in the road rather than going over them, but that could also be the H&R Race springs. I'm not sure how long my stock front subframe will last, but I sorta like how powerful and brutish the car feels when driving.
                    • CorvallisBMW
                      • 13039
                      Delrin is fucking brutal, I wouldn't go near it with a 10-foot pole.
                      Good urethane shouldn't flex much more than delrin in a low frequency/high magnitude situation (like the engine shifting around under hard driving), but will be much better at absorbing high frequency/low amplitude vibrations that cause NVH.
                      • george graves
                        • 19998
                        I used new m20 mounts, and they only last about 5 years before they start to sag on the exhaust side.
                        Originally posted by Matt-B
