M20 to M40 Swap Help
  • tcblenny
    • Dec 2015
    • 10
    Hey so I'm new to all this engine swap business but I was looking for some help on swapping out my stock m20 engine from an 87 coupe to a 1997 318i engine. I've seen posts but its usually the other way around...the e36 engine is complete with engine,transmission,harness,ecu etc..
    Any help would be appreciated!! Thanks!!
  • tcblenny
    • Dec 2015
    • 10
    Sorry if this is in the wrong section I wasnt too sure where it should go
    • R1dd1ck913
      • Jul 2014
      • 382
      Why are you wanting to get rid of the m20?
      Current
      99 328i (Sold)
      91 318is M50B25TU
      89 325ix (Parted out)
      87 325is (Parted out)
      95 525i (Parted Motor for 91 318is)
      • tcblenny
        • Dec 2015
        • 10
        For better gas mileage basically. I'm not looking for anything else from it.
        • uturn
          • Dec 2010
          • 1005
          I have several e30s with different engines. M42, M20 and M30. Getting about the same mileage between all of them. I think your money would be better spent on maintenance. If you're set on doing it, nobody will stop you. Good luck!
          • lukeADE335i
            • Apr 2013
            • 1389
            Would be easier to sell the car you've got & buy a 4 cylinder unless your car is super clean and impossible to find another in similar condition.
            My e30: OEM+ with M30B35
            • curtis_luu
              • Jan 2015
              • 51
              M20B27 or B25?
              • tcblenny
                • Dec 2015
                • 10
                The m20b27. I was hoping for maybe a guide with what parts your going to need to replace to accommodate the engine instead of asking a ton of questions .
                • SpecM
                  • Oct 2005
                  • 4531
                  m40 or m44? ... I doubt either will get much better fuel economy than an b27 in good order
                  Sent from my SM-G900V using Tapatalk
                  1989 cirrisblau-metallic 325i
