Originally posted by stonea
View Post
attempting SHO v6 in my e30
sigpic'86 325es 5 speed- cosmetic mods, working out an engine swap
2000 Audi a4 quattro wagon 5 speed- bigger turbo, 20 lbs of boost, Porsche brakes, lowered on coilovers all around, aftermarket interior, etc.
'96 Camaro z28 6 speed- long tube headers, ORY, borla catback- the car sounds good, and does good burnouts... and that's all it does well
Originally posted by lukeADE335i View PostHow many degrees is the V on those engines? Looks very narrow.
Great looking inlet manifold on those - I'd seen pics of the V8 before, didn't realise there was also a 6 cylinder version. Should be nice when it's done!
If you find the 6 speed too hard, the Mazda B series pickups supposedly had a 5 speed RWD box that bolts up.
As far as I know, and I have researched pretty heavily the transmission options for these engines, the only transmission that will bolt right up is the transmission from a ford ranger with 3.0 duratec v6 (the same block as the SHO engine). This transmission is a toploader, which makes the shifter placement very poor, and there is debate about how long they will last being shifted at 8000 rpm. If you can find a '96/'97 manual bellhousing from a ford aerostar (good luck, I couldn't), you can buy an adapter plate from a company to bolt a t5 transmission on.sigpic'86 325es 5 speed- cosmetic mods, working out an engine swap
So I didn't realize anybody had been reading/commenting on this thread, as I'm use to forums sending me a email notification when someone comments. Anyway to do that on here?
The project is moving slowly, but I believe I am close to having a final adapter plate design. I added a picture of the wooden adapter plate. I ordered an aluminum plate, and hope to make the final part soon. I re-drilled the SHO flywheel for the s2000 pressure plate, but did not realize that the s2000 flywheel is a stepped flywheel- so now I need to machine that step into the SHO flywheel, shouldn't be too hard but the machine shop at my school is backed up right now. It looks like I will be able to get a very thin pilot bushing in my crank, so I'll make that soon too.
The thermostat is on the back of the engine as it will be mounted in my e30, and the thermostat itself closes off a bypass when it opens- something that could be tricky to replicate with a "remote" thermostat. I think I may ignore that problem for now and try to get the engine in the car, then come back to it.sigpic'86 325es 5 speed- cosmetic mods, working out an engine swap
Thanks, I actually contemplated the v8 SHO for a little bit, but the cam gears apparently come loose on them and subsequently ruins the engine, which gave the engines a terrible rep. After I embarked on the v6 swap, I learned that you can just weld the cam gears and after that I haven't heard of any major reliability issues. If I had known before hand, I would have more heavily considered it as an engine but I'm too far into the v6 build to think about switching engines now.sigpic'86 325es 5 speed- cosmetic mods, working out an engine swap
Jpod999: What front turn signals are those? I was thinking about making my own out of overhead light panels like they use in schools and offices.sigpic'86 325es 5 speed- cosmetic mods, working out an engine swap
Originally posted by hambler View PostJpod999: What front turn signals are those? I was thinking about making my own out of overhead light panels like they use in schools and offices.
I bought them from Abrahamas back when they were selling real MHW clears, it looks like they only have kopis (replicas) now.
Holy swap, sir! Definitely subscribing to this one! Good luck to you, looks like it'll be an awesome swap!88 325i Cabrio
04 Neon SRT-4
Originally posted by MrBurgundyIf R3v was a dude, it would pick up a tinder date naked, with a raging boner, drunk, in an e30 with a shitty interior, a missing sunroof panel, explaining how its a classic while staring at the tinder date's tits.
Originally posted by hambler View PostSo I didn't realize anybody had been reading/commenting on this thread, as I'm use to forums sending me a email notification when someone comments. Anyway to do that on here?
Edit: Agent's is how to subscribe to the thread. Mine is how often/when you want to get emailed.My Garage
Feedback
Instagram: Stone.Hopkins
Originally posted by jpod999 View PostScroll down to the Turn Signals section: http://www.abrahamsmotorsport.com/e30.html
Originally posted by supermansocks95 View PostHoly swap, sir! Definitely subscribing to this one! Good luck to you, looks like it'll be an awesome swap!
Originally posted by stonea View PostUser CP>Edit Options>Messaging & Notification>Default Thread Subscription Mode> Choose you method of email delivery.
Edit: Agent's is how to subscribe to the thread. Mine is how often/when you want to get emailed.sigpic'86 325es 5 speed- cosmetic mods, working out an engine swap
Quick update here: tomorrow morning I'm waterjetting the basic shape of the adapter plate out of 1/2" aluminum, and then it will be on to the mill to get dimensionally accurate holes. I waterjetted a plate of thin aluminum that slipped over the dowel pegs and had a hole in the middle, which allowed me to measure to the crankshaft of the engine and input shaft of the transmission to make sure the two bolt patterns are perfectly centered on each other- which they weren't. I'll just shift the two patterns relative to each other in autocad. The pipe is a slip fit over the input shaft of the transmission and just extended it out so that I could get a reading.sigpic'86 325es 5 speed- cosmetic mods, working out an engine swap
Originally posted by Farbin Kaiber View PostMotion to Request Personalized License Plate : SHOHORN
