1JZ and Getrag 260 E30
  • bmwamer
    • Dec 2016
    • 3
    Hello...
    I just bought an e30 (85 325e) With Getrag 260
    I want to make it a street legal drift car...
    I am thinking 1JZ and our biggest challenge is to mount the G260 to the 1JZ... Not sure if there is adapters for this setup or i have to cut and weld the bell housing !!!
    Looking for advice...
    Thanks a million and happy New year
  • Anthony B
    • Nov 2012
    • 308
    Any particular reason for keeping the 260 & not going a toyota box like r154? Not sure if there is an adapter out there for it.
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5589
      My buddy is doing the same swap and is using a toyo tranny. I don't know if an adapter plate is made for a 1jz to a getrag 260.
      • 2mAn
        SeƱior Mod
        • 20943
        this swap is off to a great start
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • bmwamer
          • Dec 2016
          • 3
          The Toyota tranny is too expensive...
          Also will have to modify the driveshaft too...
          • Anthony B
            • Nov 2012
            • 308
            Would still, need to modify the driveshaft with a 260 & the 1j.
            You could look to get a custom adapter plate made to suit, but that will weigh into the costs so its a 6 of one, a half dozen of the other
            • Jdesign
              • Jun 2012
              • 198
              The trans is expensive, but you have a few less expensive options.
              W58
              W55
              CD009
              ZF using a collins adapter
              The drive shaft is easy to modify yourself if you can weld and you are careful. The section I used on my car is only about 6" difference so its not even large enough to be thrown out of balance. and if it was, most drive shaft shops only charge a small amount for balancing.
              I am running a R154 in an E30 vert FYI.
              • lukeADE335i
                • Apr 2013
                • 1389
                There are adaptors for the 1UZ-FE V8, and 1JZ / 2JZ engines to Getrag & ZF gearboxes:
                I was looking at a kit at one point when I was thinking of doing a 1UZ-FE swap as Castlemaine Rod Shop down here make mounts for the 1UZ-FE into the e30 so it'd all be a bolt in proposition.
                My e30: OEM+ with M30B35
                • parkerbink
                  • Jun 2004
                  • 10138
                  Not Toyota but similar concept (also another thread raped by PB)
                  1999 BMW M3 RB26dett Conversion
                  Engine Swaps - 1999 BMW M3 RB26dett Conversion - I know this is not a 350z, but I have been a member of this forum for quite some time, and thought you all might find my recent build interesting to read/follow Hello fellow members. I am starting this thread to share and document my experience i have had and will have...
