Any M30, if it sits far enough back, is gonna touch. Thats my understanding.
Want to do an M30 swap
Joe Funk - did you end up modifying yours or still running ok ?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
OK i have a few questions.
Is it ok to run the M30 without the little pulse wire on the #6 spark plug wire? because i dont think the M20 harness has one.
And is the fuse box plug "plug and play" with the harness or do i need to move wires around? I have an 1/1986 325e fusebox, 1989 325i harness with an 1989 m30.'86 E30
'05 E53 X5
'72 Firebird
'10 Prius
'03 TundraComment
From what I have gathered- with some m30 swaps its plug and play withe the fuse box, but not all. With my swap (90 735i motor, 87 325iS car) they dont meet up at all, and therefore I need to manually splice the wiring to get it all to work okay01 325Ci
87 325iS w/ M30B35 swapComment
The plugs physically plug into each other fine....the pins don't match up though. Meaning, car no workie. I could either chane the pin placement, or just splice the maybe 7 or so wires needed without any difficultly. Even within some years, some motors will have the correct pin placement, and some won't. All depends on options, and year to year changes. Either way, just get a a hold of wiring diagrams for both the donor car and your car, and just match them up.01 325Ci
Thats where I got mine from. Just make sure you actually download them and save the ones that you need, they have them for all years, just in case the site goes offline or anything. Haynes manual at least they are pretty vague. Just my experiance, but they are better than nothing.01 325Ci
Those look pretty good. But i still dont see the pinouts for the C101 connector.
I'm so confused... I dont know whether to use the 89 325i harness or the 89 535i harness. I've been getting mixed answers about c104 connection at the very beginning of the harness that has the tach/fuel/mpg wires, some say if you dont get those right the car wont start?Last edited by JoeMadoo; 04-11-2007, 09:59 PM.'86 E30
'05 E53 X5
'72 Firebird
'10 Prius
'03 TundraComment
How do you know what to splice, are the colors the same? Which harness did you use. Does the 325i have every single connectors that the e32/e34 harness has? I know it doesn't have the pulse connector that goes on the #6 spark plug wire.'86 E30
'05 E53 X5
'72 Firebird
'10 Prius
'03 TundraComment
Hey Joe, when do you think that the motor mount arms will be available for sale? Which version of the m30 will they work on? (motor from an e24,e28,e32.e34). I will base which motor I get based on the mounts you make. My engine choise is held in your hands lol:)Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.Comment
