Want to do an M30 swap
  • JoeMadoo
    • 936
    #121
    Ya but my e32 had 3 hoses, e30 has 2.
    '86 E30
    '05 E53 X5
    '72 Firebird
    '10 Prius
    '03 Tundra
    • MrK
      • Jan 2006
      • 709
      #122
      Originally posted by euroshark
      I used the stock M30 (6 series) hoses to the heater core and they fit perfectly.
      That makes sense, since using the e34 hoses are out since the overflow tank is near the firewall on those. I guess the 6 series had the tank closer to where the e30's is.
      This is your M20 on steroids:
      • euroshark
        • Apr 2006
        • 3491
        #123
        I just went out and looked at my driveshaft, and I think that once I get the E30 csb on it, I won't even have to shorten it! It appears to be within about 1/8 inch when I hold it all up there, so maybe I will get lucky. I'll definitely keep you all posted.
        • Garageaholic
          Freestyle Fabricator
          • Dec 2005
          • 5204
          #124
          Yeah, if it's about that 1/8" shorter than you expect, you'll just have 1/8" less spline contact, but in the grand scheme of things, it's really not alot at all. My driveshaft fit perfectly as well!
          Recent Rebranding!!
          E30 SM62/S62
          E30 M60 V8
          E30 M30 Big 6!
          Instagram.com/garageaholic
          Youtube.com/garageaholic
          • euroshark
            • Apr 2006
            • 3491
            #125
            Meh, it wasn't gonna fit... I dropped it off at the driveshaft shop today. Getting 1 3/16" taken out of the front half. Should be moving under it's own power by this weekend!!! And it only took... 6 months... of laziness.
            • JoeMadoo
              • 936
              #126
              How do you take the crankshaft nut off?
              '86 E30
              '05 E53 X5
              '72 Firebird
              '10 Prius
              '03 Tundra
              • euroshark
                • Apr 2006
                • 3491
                #127
                Tons of leverage.
                You WILL need a cheater bar to slip over the end of a breaker bar.
                You have to out it back on with ~325ft/lbs as well.
                • JoeMadoo
                  • 936
                  #128
                  Well im trying to be creative and find a way to hold the engine from turning. I tryed wedging a socket extention bewteen a few pully bolts but it just bent the shit out of the bolts.
                  '86 E30
                  '05 E53 X5
                  '72 Firebird
                  '10 Prius
                  '03 Tundra
                  • euroshark
                    • Apr 2006
                    • 3491
                    #129
                    I think I used a couple bolts and a big wrench, and my dad stood on the motor to hold it still.
                    • JoeMadoo
                      • 936
                      #130
                      So i was thinkin all I need to do is stop the engine from turning right? So i went out back, got my saw, cut a 4 or so inch piece of about 3 in diameter wood from a tree, put it on top of piston #1, bolted on the head, and what do you know, off comes the nasty bolt...:loco:
                      '86 E30
                      '05 E53 X5
                      '72 Firebird
                      '10 Prius
                      '03 Tundra
                      • euroshark
                        • Apr 2006
                        • 3491
                        #131
                        Ahhhh, you know what? I used a similar method to torque the thing back on. I used two chunks of 2x4 between the crank and the block!
                        • george graves
                          • 19998
                          #132
                          wow joodoo - that must be one unhappy crank rod.
                          Honestly, it ususally takes a HUGE air compressor...and a very good TQ impact.
                          Originally posted by Matt-B
                          • Axxe
                            • Aug 2004
                            • 3355
                            #133
                            Yeah, a nice snappy or IR gun should whip it right off with 150 PSI feeding it.
                            Keep it slideways!!
                            • george graves
                              • 19998
                              #134
                              Some one hit me over the head with a BFH if I don't post a pic describing my H2o flow tommrow (sorry been meaning to do it). I used a mix of e30 and e24/e28 parts
                              (someone correct me if I am wrong, but I think e28 and e24's are 99% the same under the hood)
                              • Axxe
                                • Aug 2004
                                • 3355
                                #135
                                I threw a BFH at you the other day, should arrive pending any unforeseen customs bullshit :)
                                Keep it slideways!!
