Want to do an M30 swap
  • Funkmasta
    • May 2004
    • 7185
    #136
    :D
    Joe Funk -- Portland Oregon
    That Guy.
    03 X5. 3 liter obviously.
    • Funkmasta
      • May 2004
      • 7185
      #137
      No modification to the firewall. Room to run A/C. :D
      I love swaps.
      :D
      That Guy.
      • Funkmasta
        • May 2004
        • 7185
        #138
        The Motor mounts are going to be dressed up a little so that they look nicer. Then, mass produced. :)
        Who wants a set?
        That Guy.
        • george graves
          • 19993
          #139
          Take a hammer to that firewall Joe, you're not back far enough(from the looks of the pics, I could be wrong) - Make sure you test fit the rotor/cap, that is the closest part of the motor to the radiator.
          When your there beating away at the firewall, make some clearence in the passanger footwell for the exhaust to sneak past.
          Originally posted by Matt-B
          • euroshark
            • Apr 2006
            • 3491
            #140
            Sick, I'll buy a set next year when I build "E30 M30 Part Deux"
            • Funkmasta
              • May 2004
              • 7185
              #141
              The cap and rotor are on, and with the full weight of the motor on the mounts, the pan is 1/8" off the subframe/rack.
              The AC pulley is about a half-inch from the radiator.
              We didnt have to mod the firewall at all, but I will look into the passenger footwell thing.
              That Guy.
              • talltorontoguy
                • Apr 2006
                • 267
                #142
                Hey Joe... what version M30 are those mounts for? I've got an M30B35 and I'm looking for mounts! Hook me up?
                Rod
                Winner - Best Engine, Bimmercruise 2010
                Runner Up - e30 Wild Category, Bimmercruise 2010
                Winner - Best Cabrio, Trillium @ Tedfest 2011
                Winner - e30 Wild Category, Bimmercruise 2011
                www.vertnation.com
                My car in Berlin Klassic promo video
                • Funkmasta
                  • May 2004
                  • 7185
                  #143
                  These are for the B34 M30's... B35 mounts are soon to follow though. :)
                  What is your timeframe?
                  That Guy.
                  • Axxe
                    • Aug 2004
                    • 3355
                    #144
                    If you didn't have to modify the firewall you aren't as far back as you should be.
                    Keep it slideways!!
                    • george graves
                      • 19993
                      #145
                      Word... Or maby you should say, you're not as far back as you "could be"....
                      Also the early m30 had a big collant pipe on the back of the head - that makes for even more hammering needed...
                      Get BFH and don't be shy...The aera you clear gets compleatly covered with the head, and it causes no real damage to your car. I'm susprised at how many guys are so worried about doing this....
                      • Funkmasta
                        • May 2004
                        • 7185
                        #146
                        I have plenty of clearance on the AC pulley. I'm running the exact same motor as you, George (B35 head), and it is right up against the firewall. We did take off the insulation though. There doesnt appear to be any clearance issues anywhere, and the motor is actually fully mounted as we speak.
                        We didnt need to touch the firewall at all... If we had the B34 head, I can see how it would have been an issue.
                        That Guy.
                        • george graves
                          • 19993
                          #147
                          Hmmm, maybe yor engine bay is longer then the rest of ours!!!
                          I'll let others chime in. But I beat my firewall about 1.5" - 2". It makes for a cleaner install with the back of the head tucked neatly into the wall IMHO...Weight, ect...
                          My theory is get it back as far as you can. It's 15-20 mins at the most to do it (measure, hammer, and seal the paint with something.)
                          It sound like to make the mounts for sale, you are going to remove them and block up the motor while you copy them. At that time I *would suggest* you make them so the motor sits further back. But only a sugestion.
                          Tino over at e30.de coined the "position 1, 2, 3" thing. It's really all reliative. I'd say I'm in position 3 (far back)
                          EDIT: I have to add, I waited 3 months for a set of mounts from him (e30.de), and when they didn't show I was upset. I requested him to send another set via fedex with tracking. His responce was "I will not, anyone that gets a lost package in the US need to deal with DHL) ..very upsetting... Tino is a cool guy, but I think he is done with m30 mounts for the US... do us al a favor and hit up joe before...
                          Also, I removed the tranny insualtion as well, it just gets in the way. Just yesterday I strated installing some "dynomat" - and copy of it called "edead". Works WONDERS... I bought 20 lbs of it (60 feet) and you could get away with using only 5lbs of it of so. I installed in inside the cabin, covering where the back of the head is, and the tranny tunnel/exhause side.
                          Make my M30 sound SO SO sososososo much sicker. With out something there you end up with a lot more tranny whine, and head noise - and not in a good way. I've only done the passanger side so far, but it allows you to hear the exhause and intake SO much clearer rather then the head/tranny noise(unplesent sounds)
                          I don't mean to tell you how to do your swap(didn't want to sound like an ass or something ) - just sharing what I did, and I'm very happy with the results.
                          HTH....
                          • Funkmasta
                            • May 2004
                            • 7185
                            #148
                            HTH....
                            For sure, for sure.
                            I just figured, why beat in the firewall if you don't have to? ya know?
                            I am a HUGE fan of the M30 and really want to promote it(in swaps)! I mean... its an M20 that is just bigger and no timing belt. It is actually bullet proof! :)
                            I definitely think that an S52 has its time and place, but in reality, if you can get the same amount of power with 1/3 of the investment?
                            That Guy.
                            • george graves
                              • 19993
                              #149
                              We need to do two things to help everyone out.
                              - Rename this thread and give it a sticky "comprehensive m30 motor swap thread"
                              - come up with a standard measurment for engine placement (left, right, front and/or back)
                              Someone go nag a mod they know....I never have luck asking for thing to get things edited.
                              Joe, your discription of a m20 vs a m30 is EXACTLY was the way I was thinking the whole time I did my swap. After 3 years I think very differently about it.
                              It's has it's own character. It's a TQ monster, that also like to rev. It builds power very linearly, where a m20 you can feel it's peaks. It's TQ curve is flat, and very rewarding.
                              While the m20 needs revs to make power, the m30 just powers along, making the m20 look like a gutless wounder.
                              The m30 had alway been described as "silky smooth" by the automotive press (they couldn't believe a in-line BIG six could be so smooth) - but a m20 is smoother. A m50/s50 even more so...
                              I hear ya about the m30/s50 debate. But I'm kinda old school. And I don't think a e30 chassie (in a perfect world) is a good match with a motor that is "over smooth". You could throw in a (insert name of a very smooth jap motor here) and it just wouldn't be the same car. You need to feel the motor at idle...let it find every loose interior part you got!!! You know what I mean.
                              With that said I'd take a McHenery built s5X any day of the week!!! But i would count on spending close to 6 G's out the door.
                              Oh, and one of the first cool things you notice about a m30 in a e30....
                              When you rev it at a stop light - Yea...your car tilts about 2-3 degress...just like a big block american car would... It feels nice!
                              Oh, and starting out in second to carry the gear till 60 is fun to. Lets see. passing cars up a steep mountain road like nothing...fun. Flipping the tail out at very low speeds...fun. Tring to convince people that your little 2-door car has 3.5L in it...not so much fun.
                              Oh yea, I almost forgot. In the summer months when income is low, I swap a 4.10 diff into my car. Usually from April to July sometimes a bit longer. I end up making quite a bit of extra cash pulling out tree stumps...
                              Ohhhh LOLzzzz...
                              • Funkmasta
                                • May 2004
                                • 7185
                                #150
                                Ohhhh LOLzzzz...
                                :rofl:
                                That Guy.
