Want to do an M30 swap
  • MrK
    • Jan 2006
    • 709
    #241
    Dumb question, why isn't this a sticky yet?
    This is your M20 on steroids:
    • george graves
      • 19998
      #242
      Needs sticky and renamed....
      Originally posted by Matt-B
      • bimmer_adam69
        • Mar 2006
        • 223
        #243
        so my status is cleaning and re sealing engine...where do you guys get the plastic cover over the wiring harness against the firewall?? or what bimmer do you get it out of
        i think it really keeps the engine bay clean:)
        M stands for Money:hitler:
        • euroshark
          • Apr 2006
          • 3491
          #244
          I believe you can find the PN on Realoem.com
          It came on later E30s like the M3 and 318is iirc... Definitely helps clean stuff up.
          • JoeMadoo
            • 936
            #245
            Here is a vid of my 335 almost starting. Excuse the monkey noises.
            I'm thinkin its the AFM because it starts up good but it wont hold an idle, even if i try to r3v it up.
            '86 E30
            '05 E53 X5
            '72 Firebird
            '10 Prius
            '03 Tundra
            • ldsbeaker
              • Aug 2004
              • 3098
              #246
              man, that would kill me... to be that close.
              Slicktop City!
              • Mike325
                • Mar 2006
                • 3685
                #247
                Seriously. Nice work so far. Hey, OT, but how should I go about cleaning off surface rust and grime from my block/head so I can paint it up?
                Thanks.
                Originally posted by Kershaw
                • george graves
                  • 19998
                  #248
                  Castrol super clean for grime.
                  Navel rust Jelly for rust(Don't get any of it on aluminum parts)
                  Mineral spirts for prep - use quality paint or you'll regret it. Also - tell any one that works on your car no to spray carb cleaner or the like on or around your motor - it caused the paint to run. You can easily drop $150 in paint and misc to clean up a motor.
                  • Mike325
                    • Mar 2006
                    • 3685
                    #249
                    ^Thanks:D
                    • JoeMadoo
                      • 936
                      #250
                      Any advice guys? AFM?
                      '86 E30
                      '05 E53 X5
                      '72 Firebird
                      '10 Prius
                      '03 Tundra
                      • Funkmasta
                        • May 2004
                        • 7185
                        #251
                        MASSIVE intake leak?
                        Joe Funk -- Portland Oregon
                        That Guy.
                        03 X5. 3 liter obviously.
                        • Mike325
                          • Mar 2006
                          • 3685
                          #252
                          Funk, any word on the mount arms?
                          Your problem sounds like the afm to me. Would'nt your stock one work with this motor? People do the 027 m30 afm on the m20, and you used the m20 harness right? See if you could swap it out. Also check your intake boot, as Funk said.
                          • george graves
                            • 19998
                            #253
                            Go a spair crank position sensor you could try? It almost sounds like you have a short or broken wire in the sensor wire, and it starts, then rattels it's self disconected - just a shot in the dark.
                            • ldsbeaker
                              • Aug 2004
                              • 3098
                              #254
                              Originally posted by Mike325
                              Funk, any word on the mount arms?.
                              +1
                              Slicktop City!
                              • Funkmasta
                                • May 2004
                                • 7185
                                #255
                                Looking into Mass fabrication since last week... found a metalworking shop that has the tooling and ability, so... hopefully soon eh? :)
                                That Guy.
