Want to do an M30 swap
  • lifeiskaos
    • 1709
    #391
    you're wanting to cut here??:
    that's scary... definitely fab some reinforcements. at LEAST a strut brace.
    • Good & Tight
      • Apr 2004
      • 2057
      #392
      BFH no need to cut anything.
      Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
      ____________________________
      E-mail Panayiotisx2@gmail.com
      Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
      • JoeMadoo
        • 936
        #393
        really? It dosent seem possible. But i trust you man, ill give it a shot... It needs to go in atleast in inch
        '86 E30
        '05 E53 X5
        '72 Firebird
        '10 Prius
        '03 Tundra
        • Spinning Tires
          • Feb 2007
          • 283
          #394
          Hammer will definately work. That metal is flimsy as shit right there. you can probably use a plastic toy hammer
          First: 1984 318i
          Second: 1987 325
          Third: 1987 325is
          Current: 1990 325i (Soon To Be 335i)
          • Good & Tight
            • Apr 2004
            • 2057
            #395
            An inch should be no problem.
            • JoeMadoo
              • 936
              #396
              Good place to drain?
              '86 E30
              '05 E53 X5
              '72 Firebird
              '10 Prius
              '03 Tundra
              • Danny
                • 14216
                #397
                Yep that'll work.
                • JoeMadoo
                  • 936
                  #398
                  Team Joe motor mount brackets
                  '86 E30
                  '05 E53 X5
                  '72 Firebird
                  '10 Prius
                  '03 Tundra
                  • kronus
                    • Apr 2008
                    • 13032
                    #399
                    Any reason you're not using all four bolt holes? Look sweet otherwise, better than my e30.de mounts :p
                    cars beep boop
                    • Funkmasta
                      • May 2004
                      • 7185
                      #400
                      booyah
                      Joe Funk -- Portland Oregon
                      That Guy.
                      03 X5. 3 liter obviously.
                      • Funkmasta
                        • May 2004
                        • 7185
                        #401
                        Definitely strong enough with just the three...
                        That Guy.
                        • sefb222
                          • Apr 2007
                          • 1206
                          #402
                          powdercoat them bitches! (go ahead joe.. post em)
                          Originally posted by Holland
                          There should be a restraining order to keep kids 100 feet from that car at all times. Plus execution on the sight to anyone who places a shopping cart within 200 feet of the thing.
                          • JoeMadoo
                            • 936
                            #403
                            There are only 3 bolt holes in the block...
                            '86 E30
                            '05 E53 X5
                            '72 Firebird
                            '10 Prius
                            '03 Tundra
                            • JoeMadoo
                              • 936
                              #404
                              Progess, who needs a vacation on spring break when you got a turbo'd m30 right?
                              Still need fmic, injectors, and a wideband o2
                              '86 E30
                              '05 E53 X5
                              '72 Firebird
                              '10 Prius
                              '03 Tundra
                              • Spinning Tires
                                • Feb 2007
                                • 283
                                #405
                                Broken distributor cap :(
                                Those intake tubes look way taller in the other pic. That will prolly fit easier since the AFM isnt up there
                                First: 1984 318i
                                Second: 1987 325
                                Third: 1987 325is
