Want to do an M30 swap
  • Danny
    • 14216
    #361
    Get green top injectors from a volvo 240 or 740 turbo.
    Those are 29lbs (300cc), should save you some money.
    • JoeMadoo
      • 936
      #362
      I am going to run megasquirt so I can ditch my afm and try and get a nice tune.
      I did hammer the firewall a bit around the head but not that much. But before I put it back in i need to hammer alot more so I can move the engine back. As it is now the wastegate hits the lower side of the strut tower and the turbo hits my motor mount.
      I'll check the junkyard for the green top's. Any other cars to look for with similar cc's? I know some fords had 28lbs
      '86 E30
      '05 E53 X5
      '72 Firebird
      '10 Prius
      '03 Tundra
      • JoeMadoo
        • 936
        #363
        Turbo Things
        New M8x110 studs and m8/m10 spacers.
        e23 Turbo manifold flat black.
        e23 Jetronic Wastegate
        More random parts
        New sound insulation, thank god.
        '86 E30
        '05 E53 X5
        '72 Firebird
        '10 Prius
        '03 Tundra
        • Good & Tight
          • Apr 2004
          • 2057
          #364
          Lookin good Joe your gonna love all the powa!! Keep it low boost and it will be safe for the engine and you.
          Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
          ____________________________
          E-mail Panayiotisx2@gmail.com
          Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
          • ZM Blue Devil
            • Dec 2006
            • 13836
            #365
            Joe,
            Do you need any wiring? I have the complete wiring from a 745 turbo. Pm if interested.
            L
            Levent
            %20levent@gutenparts.com
            Ladies:
            • yert315
              • 2734
              #366
              wow, so what kind of numbers are you looking at? And what PSI do you plan on running?
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                #367
                You can call me Brandon.
                • JoeMadoo
                  • 936
                  #368
                  You da man!
                  Will do, thanks for the kind words.
                  I dont want to run too much boost, I'll probably just keep the wastegate how it is around 9 or 10psi. If I had to estimate I guess it should should add atleast 100hp. Nothing like good and tights hw numbers though :(
                  '86 E30
                  '05 E53 X5
                  '72 Firebird
                  '10 Prius
                  '03 Tundra
                  • Farbin Kaiber
                    Lil' Puppet
                    • 29502
                    #369
                    What is the time frame of stuffing this bad boy in?
                    • kronus
                      • Apr 2008
                      • 13032
                      #370
                      Wow, nice. Are you going to be using the 745i ecu?
                      Looks like getting at the #4 plug will be fun...
                      cars beep boop
                      • JoeMadoo
                        • 936
                        #371
                        Its going to be megasquirted.
                        I'm trying to get done as fast as I can, still need to get injectors, oil lines, and a new right side motor mount...
                        '86 E30
                        '05 E53 X5
                        '72 Firebird
                        '10 Prius
                        '03 Tundra
                        • Doughnut
                          • Oct 2007
                          • 869
                          #372
                          That e23 exhaust manifold is badass!
                          ///Monstrosity. (OO≡≡[][]≡≡OO)
                          Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
                          • speedhop
                            • 1509
                            #373
                            Hehe...he said megasquirted. :giggle:
                            Great work! I can't wait to see the power you put down!!!
                            www.ryanwhopkins.com
                            • LowR3V'in
                              • 4209
                              #374
                              :) It's looking very nice :)
                              • JoeMadoo
                                • 936
                                #375
                                Some updates/questions...
                                Oil feed and pressure sensor installed.
                                These two connections... Where do they go??
                                And these two vacuum lines... One goes to the FPR, the other goes to the intake boot. But what is the purpose of the one that goes to the intake boot, is that really needed for a turbo system?
                                Need a new flange... JOE FUNK!
                                '86 E30
                                '05 E53 X5
                                '72 Firebird
                                '10 Prius
                                '03 Tundra
