Just dynoed my m30b35... not pleased.
  • MrK
    • Jan 2006
    • 709
    I just got back from the dyno, and I am (to say the least) quite disappointed.
    the dyno sheet showed me a 'corrected' 141.8 Kw, or about 190 hp at the crank :(
    That is LOW for an M30B35. I also noticed that the car was running a little richer than it should (smoke out of the exhaust).
    I checked compression, and it's practically perfect across all cylinders. Air filter and fuel filter are new, sparks are new.
    I'm stumped. Anyone know what may be going on?
    This is your M20 on steroids:
  • bmw335isturbo
    • Mar 2006
    • 218
    190 hp not bad what were you looking for ?
    I would check the A/R, Because you were saying it is running rich.
    I would also try opening up the intake side Filter,Big bore throttle body. and what kind of exhost are you running?
    I would say 190 hp at the crank is not bad I would think 190-205 and would not expect much more.
    1986 335is-1988 335ist -1991 335istsigpic
    • terrybpp
      • Sep 2004
      • 340
      Are you using a euro e28 or e34 motor? The e34 had the most hp at 211. Add a few hundred thousand miles to that and you would be right around your #. Have you ever had it rebuilt?
      • JGood
        • Jan 2004
        • 7959
        nm I see you said crank
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • Mike325
          • Mar 2006
          • 3685
          You said crank hp. How do you do that with the engine in the car?
          Originally posted by Kershaw
          • Garageaholic
            Freestyle Fabricator
            • Dec 2005
            • 5204
            Crank HP = (RHWP *.15)-RWHP
            I'd say take 15% from the crank HP and you get the rear wheel hp.
            What do you guys think it is for drivetrain loss in an E30?
            Recent Rebranding!!
            E30 SM62/S62
            E30 M60 V8
            E30 M30 Big 6!
            Instagram.com/garageaholic
            Youtube.com/garageaholic
            • Jean
              • 18228
              It put down 142 at the wheels correct ? How much tq ?
              • euroshark
                • Apr 2006
                • 3491
                Do you have an aftermarket chip installed in the ECU? How is the condition of the exhaust? I would guess possibly a bad air flow meter, or bad cat.
                • MrK
                  • Jan 2006
                  • 709
                  No cat, and yes it had a chip in it. I replaced the stock chip and it ran much better. No more rich condition that's for sure. Oh, and I'm running a stock e30 exhaust, but with dual 2" pipes (a la 535i size). I haven't had the head rebuilt, but the engine only had 90k km on it, and compression tests revealed that all the cylinders were within 1 psi of stock spec. Oh, and the motor is a Euro M30B35 '92. According to my research, that should produce 218hp at the crank stock.
                  • bumpstop335i
                    • Mar 2006
                    • 64
                    i got 135kw @ the wheels. with 380nm with a autobox m30b35 92' 735i
                    • CarsSuck
                      • Oct 2005
                      • 968
                      its an engine design from the eff'ing sixties, what do you expect?
                      --Will
                      • george graves
                        • 19995
                        Ummm what?
                        Originally posted by Matt-B
                        • Mystikal
                          Wheel Fitment Expert
                          • 9602
                          Air filter, fuel filter, o2 sensor...plenty could be wrong.
                          I'd start by dynoing again with A/F readings. I think doing without is useless anyways.
                          • bumpstop335i
                            • Mar 2006
                            • 64
                            im in need of a rising rate FPR. MrK does your dyno look like this?
                            • MrK
                              • Jan 2006
                              • 709
                              I don't have my dyno plot at hand ATM, but the curve is much smoother than yours... I don't think I have an A/F ratio problem... My hp curve goes up to almost max at around 3.5k rpm and just rises slightly after that, dropping off at about 6.1K rpm.
