M30 E30 official roll call thread
This is a sticky topic.
  • Jean
    • 18228
    #76
    kylekrueger - e34 radiator? what engine mounts are you using? can you post some pictures.
    • Chico335i
      • 42
      #77
      Chasis e30 1985
      M30b35
      Made in Germany by Liebig
      megasquirt I
      Costa Rica
      Delphin Metalic 335i 1985
      • LowR3V'in
        • 4209
        #78
        Engine pics?
        • Chico335i
          • 42
          #79
          This photos are a few years ago, in paint and engine jobs...
          I take more in this days.
          • Heysüß
            • 911
            #80
            just bought a M30 E30 !
            you'll hear from me soon enough, as this is my first E30 period, I will have a lot of questions as soon as I'm out school for the semester.
            09/1989 325i 4 Door
            +M30 Swap
            +Z3 Steering Rack
            • 240sxpooter
              • 2
              #81
              M30 swap soon to be gt42 powered!!!!
              Hey guys wanted to post up some swapped e30 pic's. If things go well and i sell my supra im planning on installing a gt4294 turbo on it and making around 400-500 whp with it.
              Started like this. No engine , wheels, hood, etc...
              Ended up swapping a 1984 733i power plant. during the install i added a set of stahl headers.
              Now
              Dyno dynamic's numbers
              It did 150whp on a dynojet the next day. the car had has loud valves and leans out up top to 14.5 afr. Im hoping that i can use a ecu from a 1987 535is and chip it to help out the low power????
              Anyhow... Hi
              Potter
              • BMWBradford
                • 19
                #82
                1987 bmw 325i foour door yellow
                1987 535i m30b34
                e24 3,3 liter oil pan and pump
                getrag g265
                and lots more :P
                • josan88200022
                  • Jun 2010
                  • 16
                  #83
                  M30 conversion: engine mount brackets
                  I am looking for a set. Anyone kno0w where I can get my hands on a set?
                  John
                  • Bavarian Performance
                    • Dec 2010
                    • 39
                    #84
                    1987 535i m30b34
                    getrag g265
                    and lots more :P
                    Bought BMWBradford's project. Still needs to be wired up, engine mounts done and driveshaft. Have lots of questions but will do my best to do searches before asking noob questions.
                    Car used to be Miller Performances first signature car. They took it apart years ago and never got around to putting it back together. Since then it has been passed around in the local B.C. Bimmer community.
                    The drivetrain in the pictures is long gone as is the rims and 5 lug discs. Body is still in pretty good shape. Just want to get it running then slowly add performance parts. Z3 steering rack, Miller Performance W.A.R chip and exhaust and uprated sway bars and bushings.
                    Don't know what will put the bigger grin on my face. The first start up or the first time I fill the rear wheel wells with tire smoke , on a controlled race track of course!!!!:D
                    • slammin.e28
                      שמע ישראל
                      • 12054
                      #85
                      Car: 1984 325e*
                      Engine: 1985 M30B34 w/VW 92mm pistons.
                      Trans: G260/6
                      Rear: Unknown
                      Car: 1989 325is*
                      Engine: 1986 M30B34 w/M90 head, larger valves, 94mm VW pistons, custom headers, custom intake.
                      Trans: G260/6 w/lightweight flywheel (15lb)
                      Rear: 3.25 LSD
                      Car: 1985 535i
                      Engine: e34 M30B35
                      Trans: G260/6 w/533 lightweight flywheel
                      Rear: 3.73 LSD
                      *Work in progress.
                      I roll deep in the M30s. Still need one more to purge the rest of the M20s.
                      • White5
                        • 149
                        #86
                        Things done recently by me/ local shop:
                        2 views, 3 likes, 0 loves, 3 comments, 0 shares, Facebook Watch Videos from Dynotech Motorsports: Dyno Test/Tune E30 M30
                        *New Head Gasket
                        *Radiator
                        *Moved motor back 1/2" - 3/4"
                        *Coolant system hoses (all new)
                        *New Fans
                        *A/C install
                        *Painted Wrinkle Black
                        *Turner Chip
                        *Spark Plugs
                        *TPS
                        *ICV
                        Soon to come:
                        *CAI?
                        *New Coolant tank
                        *New Oil Cap
                        BEFORE:
                        AFTER:
                        • White5
                          • 149
                          #87
                          Does anyone know if I'd be better keeping the stock M30 airbox or if I should go with a custom cold air intake? The cold air has a metal barrier custom built for it to keep as much hot air away as possible but the more I read the more I wonder..
                          Thanks
                          • LowR3V'in
                            • 4209
                            #88
                            Keep the stock box.
                            Get the trumpet off a e34 or something like this.
                            • charlE30
                              • Sep 2009
                              • 11
                              #89
                              1988 zinnobar red tourer
                              E34 M30B35
                              e30.de engine mounts
                              E34 manual 5spd trans
                              E28 ligtweight fly with matching clutch
                              B&M race quick shifter
                              Sebring stainless steel exhaust system
                              E30 M3 prop
                              3.91LSD
                              E46 330ci clubsport steering rack (3 turns lock to lock)
                              Powerflex bushes inc eccentric fronts
                              Bilstein B6 shocks
                              Apex 60/40mm springs
                              Brembo discs and fast road pads
                              Nearly every BMW option ticked from new ;)
                              Just finished putting the M30 back together after replacing all gaskets and seals with ultrasonically cleaned injectors. Can't wait to get it back in
                              Charlie
                              88 335i zinnobar tourer fully loaded ;)
                              • uturn
                                • Dec 2010
                                • 1001
                                #90
                                1991 325i
                                1992 E34 M30B35 top end
                                1988 E32 M30B35 bottom end
                                Alpina engine brackets sourced from KOED
                                E30 325e driveshaft (for the larger guibo)
                                3.25 LSD from a 528td
