m10 to m30
  • hendrixvodu
    • Jan 2007
    • 2514
    Originally posted by flawdaboi407
    Nice. I just might do it! But mine will have a 75shot! Also I have a 84' 318i car.. so I use the 320i harness? There kinda impossible to find and the one imprted car I fund it was gone.... I did get the bumpers :) Isnt the 87 325e harness the same? Thanks.
    p.s dont you mean 215mm clutch?
    agreed 320 = impossible to find.....but what do you think about this 87 E harness? ive heard the same thing....think it will work for the m10 set up?
    if that harness works....our m10 cars will be ideal for the m30 swap :D
    -His-
    87 e30 325i
    87 e24 m6
    05 e83 x3
    94 e32 740i 5spd
    -Hers-
    89 e30 325i
    18 f48 x1
    • flawdaboi407
      • Mar 2008
      • 324
      ^ yes sir. Does the ecu plug right in on m10 cars?
      84' 318i m30b35 swapped!
      • gstuning
        • 833
        All depends on the engine to be used and the ecu to run it.
        you can not use a motronic that uses flywheel sensors because the m10 doesn´t have
        any mounting points. so it´s motronic 1.3 only and front timing wheel.
        There are only a very few wires you need to wire to start the engine to the car.
        starter is black/yellow
        coil is green wire
        rpm on motronic 1.3 is black in the round connector
        blue is alternator - sometimes there are two blue so measure to double check
        fuel pump varies a bit and needs to be checked from m10 harness and relays.
        same with m1.3 harness.
        Gunni
        @ Prodrive / Aston Martin Racing
        • hendrixvodu
          • Jan 2007
          • 2514
          coil is green wire
          shit my car is jetronic ....does this mean i am screwed? ....is it going to be impossible to wire up this engine and fuse box?
          -His-
          87 e30 325i
          87 e24 m6
          05 e83 x3
          94 e32 740i 5spd
          -Hers-
          89 e30 325i
          18 f48 x1
          • hendrixvodu
            • Jan 2007
            • 2514
            also....could i use that motronics harness....and then wire the c101 plug? is that the plug that everyone rewires? ...and if i can do that....what do i do about the fuse box?
            P.S. sorry if these are dumb questions....but i cant find shit on this swap for the m10
            -His-
            87 e30 325i
            87 e24 m6
            05 e83 x3
            94 e32 740i 5spd
            -Hers-
            89 e30 325i
            18 f48 x1
            • flawdaboi407
              • Mar 2008
              • 324
              ^ me ither.. the wiring part has me thinking
              • gstuning
                • 833
                You don´t do anything with the fuse box.
                you just find the wire colors mentioned,
                all m10s are jetronic.
                if you have a early m30 you will need the later m30 motronic front crank sensor and timing wheel on the front. I.e update the engine to later motronic you don´t have to do that with the later m30´s. you can then get a m20b25 motronic loom and use that.
                but you will need to rewire the loom a bit to connect to the m10 box connector.
                best would be to locate a m10 wiring diagram and trace the m30 side to the m10 side.
                Gunni
                • hendrixvodu
                  • Jan 2007
                  • 2514
                  that sounds promising! ...well im going to get a late model e34 oil pan and AFM this week.... do you have any idea where i could find either of the wiring guides for these cars?
                  by the way...i just wanted to tell you that you have helped me out A LOT!!! i really appreciate all your time and help! :up:
                  -His-
                  87 e30 325i
                  87 e24 m6
                  05 e83 x3
                  94 e32 740i 5spd
                  -Hers-
                  89 e30 325i
                  18 f48 x1
                  • flawdaboi407
                    • Mar 2008
                    • 324
                    what flywheel did you use with the m10 tranny? I assue the m10 one right?
                    • hendrixvodu
                      • Jan 2007
                      • 2514
                      havent got one yet....i was just gunna use all new m10 clutch parts ....me and my friend figured the car would be light enough to use that clutch
                      -His-
                      87 e30 325i
                      87 e24 m6
                      05 e83 x3
                      94 e32 740i 5spd
                      -Hers-
                      89 e30 325i
                      18 f48 x1
                      • flawdaboi407
                        • Mar 2008
                        • 324
                        Heres a pic I saved a while ago...
                        • hendrixvodu
                          • Jan 2007
                          • 2514
                          flawdaboi407
                          dude that helps out a lot!!!!!! much thanks!! im saving the image as of now lol!
                          -His-
                          87 e30 325i
                          87 e24 m6
                          05 e83 x3
                          94 e32 740i 5spd
                          -Hers-
                          89 e30 325i
                          18 f48 x1
                          • flawdaboi407
                            • Mar 2008
                            • 324
                            that pic i got from n8bmws thread and the info is from g&t for wiring msII. but its shuld be the same for the harness.
                            • Antrieb325
                              • Jun 2005
                              • 118
                              I realize this is an old thread, however I have a bare '84 318i shell, and a running (but wrecked) '90 535i manual. So I was planning on swapping in this drivetrain into the 318i, but all the electrical is out of the 318i. Can I use the complete M30 E34 wiring harness in the 318i and not mess with E30 electronics? I shouldn't need any electronics from an E30 correct?
                              Thanks,
                              Korey
                              • Antrieb325
                                • Jun 2005
                                • 118
                                Bump..anybody?
