I'm looking for a "volunteer" in the Puget Sound
  • hoveringuy
    • Dec 2005
    • 2751
    With benefits!
    Ok, so if you guys haven't followed the story at the DOHC board here it is for review.
    I've developed the circuitry to convert the fuel signal for larger motors to something that the OBC will interpret correctly so that your OBC works for MPG.
    Yes, I've fixed the econo gauge.
    It is working great on the DOHC motors and I'm looking for someone in the Seattle area with an M30 that is interested in correcting the problem on your car.
    I assume the M30's have the same problem. You get wildly optimistic MPG readings from your OBC after the swap.
    I will install the small circuit on your car. You get to keep it in exchange for your feedback on how well it works. I'll be in Seattle from the 13th - 21st of May.
    How 'bout it?
  • george graves
    • 20003
    My OBC/MPG reads correctly more or less.
    Originally posted by Matt-B
    • Funkmasta
      • May 2004
      • 7185
      My range is WAAAAAAAAAY off, but my MPGs is not far off.
      That being said, I am interested...
      -Joe
      Joe Funk -- Portland Oregon
      That Guy.
      03 X5. 3 liter obviously.
      • hoveringuy
        • Dec 2005
        • 2751
        I honestly have no idea if it's an issue with the M30. I would have guessed that with bigger injectors and a bigger motor your OBC mileage would be waaay off.
        Is that not the case?
        With the M50 I read about 45-50mpg on average.
        Are you guys actually reading accurately??
        • JoeMadoo
          • 936
          I'm pretty sure mine is correct also...
          '86 E30
          '05 E53 X5
          '72 Firebird
          '10 Prius
          '03 Tundra
          • Funkmasta
            • May 2004
            • 7185
            my mpg is fairly accurate, maybe slightly optomistic.
            My range is SO far off. same?
            That Guy.
            • WillisE30
              • Jan 2007
              • 831
              Originally posted by hoveringuy
              With benefits!
              How 'bout it?
              If you want to get together and shoot the over some beers drop me a PM.
              sigpicFormer professional wrench thrower.
              Current:
              1988 325is S52
              Former:
              2008 Sparkling Graphite M3 Sedan(victim of home ownership)
              1988 M5
              1996 328is
              • hoveringuy
                • Dec 2005
                • 2751
                I'm bummed that I won't be there for the picnic but I'm always up for a get together.
                I'm a little bit suprised that you guys are getting accurate MPG but your range is way off. They should be going hand-in-hand.
                The problem with the DOHC motors is that the larger injectors fool the OBC into thinking less gas is being used because it bases the injector duty cycle on 14lb injectors. Less gas used makes it think MPG is much better.
                Definitely weird... why doens't the M30 do the same thing???
