thank you guys, im about to go outside and take a look so i'll check back with wire color and such
Pin Outs! i need them
ok im confused about this power to my ECU issue can some one explain it a little more??? all i need is the ECu to get power for this thing to start up!Comment
In M20 wiring, the ECU gets power through the 3-poled connector in glovebox.
In M30 wiring, the ECU gets power through the 63-poled big connector which connects to ECU box.
So all you need to do, is to run a jumper wire from 3-poled connector in glovebox, to the round connector where car wiring set connects to engine wiring set. Correct pins can be found on www.e30.de schematics.- E34 M5 (x 2) -
- E30 V8 Cabrio "Kylpyamme" -
- Alpina D10 Touring #33/94 -
- E46 318i Touring -
- Toyota Hiace 4wd -Comment
