Ok, I thought a m30 swap was difficult enough in terms of engine wiring etc... But that looks like a nightmare! Good luck
32v > 24v >12v (v8 is gr8)
basically its an m50 swap on the wiring side of things.... not too bad once you get the obd1 harness....
i'm getting ready to make the x20-c101 connector and 90% of the wires are the same as with the m50 swap :DComment
You make it sound sooo simple lol, big thumbs up for doing this swap!Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
This should be moved to the projects forum. More people need to see this.
Thread discussing obd1 conversions on m62s
Bimmerforums is the preferred online BMW Forum and community for BMW owners. At Bimmerforums, you will find technical how-to information maintenance specifics audio advice wheel and tire combinations and model specific details not found anywhere else. Our professionals are here to help make sure you find the answers you need to your questions and our community is here to help other brainstorm ideas for the future.Last edited by madjurgen; 07-25-2008, 10:40 PM.
As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.Comment
http://forums.bimmerforums.com/forum...&highlight=m62Comment
some motivation to get the show on the road. :D
the motor mounts showed up today going to go powdercoat them tomorrow morning :DComment
Like I said before...
You're going to need a bigger shoe horn...
I know you can do it, its just not an easy fit from what I have read before.
Hang in there you will get it worked out though. It will be awesome when you do too...
:up:Comment
