Considering M30 swap
  • RickSloan
    • 2401
    #106
    Originally posted by Spinning Tires
    b34
    got the whole e28 5 speed for $300
    I still have the hydra boost setup but i dont really wanna use it i was thinking of putting an elbow on the bottom kind of out of site
    go for the bottom, thats what i did and its like its not even there. i went for the middle tho, i would say come out toward the edge a bit more so it doesnt get in the way of the coolant hoses.
    Need Illustration or Design work? www.robbiebyerly.com
    • Spinning Tires
      • Feb 2007
      • 283
      #107
      I just ordered the intake gaskets from Advance Auto and they can get me 5 by tomorrow and the last one in 3 days. Fuckin idiots. Sell them as a package deal. Who's gonna change just one gasket?
      First: 1984 318i
      Second: 1987 325
      Third: 1987 325is
      Current: 1990 325i (Soon To Be 335i)
      • kronus
        • Apr 2008
        • 13027
        #108
        next round of questions:
        Will a stock 325i exhaust system choke a stock M30B32?
        Can you run a B32 on an 059 ECU, chip tuned for B34, and Motronic 1.0 harness? (afaik B32 used a different ECU...)
        cars beep boop
        • euroshark
          • Apr 2006
          • 3491
          #109
          The stock exhaust will flow fine for a 3.2. Single 2.5" ID pipe is actually more than adequate for the 3.4.
          As long as you are using the correct harness and associated parts (AFM, ICV, sensors) the 059 ECU should do a great job of running a B32.
          • RickSloan
            • 2401
            #110
            honestly the down side to stock is the sound....
            after running open headers and now having close to stock sounding it really really isnt the same...
            • kronus
              • Apr 2008
              • 13027
              #111
              What's so bad about quiet? As long as the pipes are fine, I can just lop off the stock Bosal muffler and put on something nice later on... I have dreams of a B&B Triflo sitting where the spare tire well currently is.
              Euroshark, thanks for the help. Informative and useful comments as always :D
              Anyone know if the M10 trans from an '84 318i has an OD fifth gear? I have found several different sets of gear ratios online so far...
              cars beep boop
              • mooseheadm5
                • Apr 2009
                • 375
                #112
                Dunno who told you you could use your early M20B27 harness with an M30B34, but you can't. They don't have the same type of idle control system. You can probably use it with an M30B32 as they have the same type of Motronic. If you had an E30 Super eta (1988 ) you might be able to use your harness with an M30B35 from an E32/34 as they have the same type of Motronic (you may have to lengthen a few wires.)
                -P
                Moosehead Engineering
                • mooseheadm5
                  • Apr 2009
                  • 375
                  #113
                  Originally posted by wildstoats
                  The B34's had a 3.3/3.4 stamping on the side and the B35's just have a 3.5 stamped on the side.
                  It says 3.2/3.5
                  -P
                  • kronus
                    • Apr 2008
                    • 13027
                    #114
                    AFAIK M30B34 and M20B27 both use Motronic 1.0... have you run into this? Where do they differ?
                    cars beep boop
                    • RickSloan
                      • 2401
                      #115
                      this is right i believe, both should have reference sensors on the bell housing and up front
                      and about it being quiet, its fine thats not the issue. Its going from the amazing sound of that motor be loud, to not being able to hear it at all... i drove it for 3 months with just about no exhaust its sounded so mean
                      • mooseheadm5
                        • Apr 2009
                        • 375
                        #116
                        M30B34 uses a 3 wire idle control valve. M20B27 (exc 88 super eta) uses green box with 2 wire idle control valve. Both do use the bell housing sensors, but the geen box changes everything. Sorry, but you have to do some wiring. It is not that big a deal, though.
                        -P
                        • kronus
                          • Apr 2008
                          • 13027
                          #117
                          So does the early M30 ICV wire directly into the ECU? Wiring is not something I'm averse to, and this is betting than getting caught by surprise.
                          Do you know where I can locate an E28 ETM? I'm going to be using my ETA Motronic 1.0 harness with an 059 ECU, might as well check the wiring I'll need to do.
                          cars beep boop
                          • mooseheadm5
                            • Apr 2009
                            • 375
                            #118
                            The M30B34 (and B35) ICV wires directly to the computer. The M20B27 (and M30B32) goes through the green box, and IIRC, some other signals go through there too, so it will be much splicing and screwing around to get it to work. PM me your email addy. I'll see what I can do about the ETM.
                            -P
                            • wildstoats
                              • Sep 2007
                              • 896
                              #119
                              I have a copy of the e28 ETM. I can email it to you if you want.
                              • kronus
                                • Apr 2008
                                • 13027
                                #120
                                bump because I'm on the hunt again.
                                Going to look at a 633CSi tomorrow, has a low-miles M30B32 with L-Jetronic management (I think).
                                Questions:
                                Does the 633 come with a getrag 260/5 or a getrag 265?
                                Does it have bellhousing sensors?
                                Does it have a 3.46LSD? It has some sort of LSD, but I'm not sure if it's 3.25 or 3.46.
                                Looks like I'll need both an E24 and an E28 ETM.
                                cars beep boop
