Considering M30 swap
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
It's on hold for now, economy is affecting my job so... I have to watch my spending..
It's basically down to ordering the engine mounts/clutch kit/radiator/hoses and getting the exhaust figured out.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Mine was 170+ on all cylinders @ 315kbump because I have more redundant questions (although answers to them may be useful to people looking for collected info in the future)
What are good compression numbers for an M30 with north of 220K miles? The one I'm looking at has ~140 all around.
Also, if the head is taken off, is there anything I can replace cheaply and easily along with the head gasket? (May as well get a complete gasket kit and go through it.)
factory is 168-175'89 335is +turboComment
Looking quite longingly at an M30B32 now.
I need a favor from someone who used an 87 eta driveshaft with no modifications: can you please tell me the model of the trans you used and its length from bellhousing edge to output flange? Need to figure out if the M10 trans I'm using is of a similar length.Comment
i have both the trans i used and m10 trans sitting in my garage, ill set them next to each other today and get back to you.Looking quite longingly at an M30B32 now.
i checked tonight, trans are almost the exact same size as far as the body, maybe half an inch different. Its the output flange that is different in length. The M10 flange is shorter by maybe an inch.
so overall i would say the difference is an inch and a half with stock output flanges, half an inch if you switched flangesComment
FUUUUUCK. Why didnt I think about putting a fitting on for the brake booster? I already installed the intake with new gaskets and some of that indian head sealant. There goes another week waiting for new gasketsFirst: 1984 318i
Second: 1987 325
Third: 1987 325is
Current: 1990 325i (Soon To Be 335i)Comment
i have a plumbed intake, its dirty and they plumbed it right above the the 3.2/3.5 kinda off center but its done.
are you b34 or b35?
shame about the gaskets man...Comment
b34
got the whole e28 5 speed for $300
I still have the hydra boost setup but i dont really wanna use it i was thinking of putting an elbow on the bottom kind of out of siteFirst: 1984 318i
Second: 1987 325
Third: 1987 325is
Perhaps a T off the IAC Intake hoseFirst: 1984 318i
Second: 1987 325
Third: 1987 325is
