M30 5spd
  • Jean
    • 18228
    #256
    Originally posted by Jon325i
    Excellent work, Jean. I want to test drive this bad boy sometime. Sounds wicked
    Sure thing, maybe at the next coffee gtg?
    • Doughnut
      • Oct 2007
      • 869
      #257
      Get the covers on that rotor cap ASAP!
      Something to this effect looks much better:
      Please excuse the hot air intake, it was temporary.
      ///Monstrosity. (OO≡≡[][]≡≡OO)
      Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
      • Jean
        • 18228
        #258
        Why the cover? I actually have it, but left it out because I didn't see how it would cause any problems and didn't want to bother with it due to clearance as well.
        P.S. I see you used an m20 overflow tank, what did you do with the hoses to get it to fit?
        • Jean
          • 18228
          #259
          Man I am pissed. Pulled my early cluster today to install a late model cluster so that tach would read correctly instead of 1500rpm idle and install check engine light...
          Resoldered all the connections on the main board in the cluster, installed early style fuel gauge meter in the late model cluster. Checked all bulbs, replaced a few. Installed it in the car, turn the key on and the tach is dead on at about 800 rpm now, temp and fuel gauge work as they should, odometer/speedometer working as well. But the f-ing SI board is bad.... it won't reset through pin 7 to 19.
          • whiltebeitel
            • Apr 2007
            • 2098
            #260
            I'll check and see if the spare I have in College Station is in good shape (should be) I think it's a motometer. You interested? I'll help out a nice m30 swap!
            '89 325i track sloot
            '01 530i daily
            -Enginerd
            • Jean
              • 18228
              #261
              Thanks for the offer! I am going to look for one tomorrow, but if I don't find one I'll PM you?
              • Japandrew73
                • 2164
                #262
                Those god damn SI boards ruin so many clusters. They really should have picked a different battery or found a way to prevent the leaking from spreading like it does.
                • Jean
                  • 18228
                  #263
                  My early cluster is 100% working, it even has brand new gears and it's got a newer model (probably a replacement) SI board with newer batteries. You can actually bypass the SI board in the early clusters, I did that for months until I got a newer board.
                  But this late model cluster was just my luck, I kept it from my other e30.
                  • 416stroker
                    • May 2008
                    • 2448
                    #264
                    Great I want a ride in it. You do great work Jean it looks very clean
                    84 318I Delphin RIP
                    87 325IS delphin 24v Sold
                    89 325 Alpineweiss
                    • Japandrew73
                      • 2164
                      #265
                      My early cluster is 100% working, it even has brand new gears and it's got a late model (probably a replacement) SI board with newer batteries. You can actually bypass the SI board in the early clusters, I did that for months until I got a newer board.
                      You put the late model SI board in your early model instrument cluster??? How does that work out? The lights are different colors on the early and late clusters. Is there any technical differences or is it a straight swap?
                      • Jean
                        • 18228
                        #266
                        No. I removed my early cluster to install a late model in order for the tach to read properly (4cyl to 6cyl). I should have not said "late model", edited my previous post. It's an early newer board, basically must have been a replacement board. I was just trying to explain to you that in the early cluster you cay bypass the SI board.
                        • whiltebeitel
                          • Apr 2007
                          • 2098
                          #267
                          Yeah, PM me if you want it.
                          '01 530i daily
                          -Enginerd
                          • yert315
                            • 2734
                            #268
                            can't you just swap coding plugs from a 6cyl tach? I don't know if you can do it with the early clusters, but it's a thought.
                            • hugh jass
                              • 2220
                              #269
                              nice work man. let me know when you want to do a/c.
                              ______________________
                              ex-Chief Operating Officer
                              Blunt Tech Industries
                              West Coast and Pacific Rim
                              • germancarsonly
                                • Mar 2008
                                • 1350
                                #270
                                I looked at Jean's 318i today and he really did a nice job on the swap.
                                Then I went for a ride with him. This car is really quick and probably will eat Twin Cam cars for lunch.
