Both sets had wear when I checked them out @315k. It's cheap, do both, IMO.
M30 5spd
This one is at 1/2 the mileage, I've read that these bottom ends usually don't wear out as much as the 4cyl models so maybe I'll just leave it alone.
I did order a new water pump/t-stat and about to order a new clutch kit. Are the e34 535i clutch kits the same as 635csi and e28 535i?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
From autohausaz, m5 clutch will be overkill (and will require m5 flywheel?) if the engine isn't boosted no?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
no need for an m5 pressure plate with the m5 clutch, the m5 clutch kit relly isnt muc more money at all and im super happy with itComment
payed $320 for mine, pressure plate, clutch disc, and TOBComment
I am looking at autohausaz, got a link?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
I used autohausaz and picked a 91 735i and it shows 11241258428 for a set of bearings, but according to realoem these are not for E32/E34.
Can someone confirm this?
http://www.realoem.com/bmw/showparts...70&hg=11&fg=20
What is the deal with RED and BLUE bearings? Do I have to get 6 of each?Last edited by Jean; 05-14-2009, 05:28 PM.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Sent autohausaz an email to confirm if the part number was correct:
"Thank you for submitting your part inquiry with Autohaus Arizona. Part
number 11 24 1 258 428 / 6 would be the correct standard main bearing
set for the 1988 through 1992 BMW M30 engines used in the E32 735i and
E34 535i. This is a complete bearing set for the six cylinder engines
and is manufactured by Glyco, which is a division of Federal-Mogul."Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Just throwing it out there as an option.Comment
Made some progress today, tore into the bottom end and cleaned up the pistons. Next week new piston rings/bearings are getting installed along with the rest of it if time permits.
Old timing rails after 160k miles:
Original rod bearings didn't show much wear
old vs new
can see the wear here
Chains didn't appear to be stretched
rods and pistons removed and marked
before cleaning
after some cleaning, the oil ring groove was a bitch to clean
close up of original piston
No wear noticed on the crank
cyl. walls
wtfbbq
That's it for today.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
I ended up ordering std. rod and main bearings since everything is apart anyway. Tips on replacing rod/main bearings such as torque #s and order of things?
I only have an e30/e36 bentley manuals, I need to pick up an e34 (535i) manual I guess.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
