Jean, post #72 was amazing, I just jizzed in my pants. Great info!
M30 5spd
My m30 will not have any oil leaks!
11121726725 Camshaft Gasket; End Plate Gasket at Rear of Cylinder Head $0.98 1 $0.98
11141250073 Crankshaft Oil Seal; Rear Crankshaft Housing Gasket $0.91 1 $0.91
11611726016 Intake Manifold Gasket $1.74 6 $10.44
007603-012102 Oil Drain Plug Gasket; 12mm Copper Seal Washer; 12x16x1.5mm $0.25 1 $0.25
11131273093 Oil Drain Plug; 12x1.5mm $1.76 1 $1.76
026103485 Oil Filler Cap; Plastic $2.47 1 $2.47
72128 Oil Filter $4.80 1 $4.80
12611277129 Oil Level Sender Gasket; O-Ring $1.68 1 $1.68
11131722695 Oil Pan Gasket $8.50 1 $8.50
12611730160 Oil Pressure Switch; With 1 Pin Injector Type Electrical Connector $5.33 1 $5.33
A6005-285788 Oil Filter Stand Gasket $2.05 1 $2.05
11531250353 Thermostat Gasket/Seal; Housing Gasket $1.49 1 $1.49
11141258323 Timing Cover Gasket Set $15.48 1 $15.48
11121730231 Valve Cover Gasket $4.40 1 $4.40Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
I forgot to order these as well, so they have been ordered too.
11141271415 Camshaft Oil Seal; 28x40x7mm $4.42 1 $4.42
11531266459 Cooling/Coolant Hose; Water Pump to Thermostat Housing $4.71 1 $4.71
11141715100 Crankshaft Oil Seal; Front; 42x62x12mm $5.99 1 $5.99
11142249533 Crankshaft Oil Seal; Rear; Updated Version; 90x110x12mm $22.07 1 $22.07
4034 Spark Plug; Platinum; Standard Electrode; OE Plug $2.85 6 $17.10
and another order from blunt is on the way too, I think by mistake I've ordered two of 11531266459.
Next to order: cap/rotor , water pump / tstat. Should be able to finish it up in the new few weeks :)Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
^ where did u buy those parts ? Are they pretty good quality?
( i bought some oil seals, gaskets at bmw online parts warehouse, turned out a couple of the items are made in china,with Erling Klinger brand, o yea...it leaks after 5000 miles !)While the other same parts made in germany dont leak.Comment
drift - autohausaz and blunt here on the forum is where I get all of my new oem parts from. And I realized that I forgot the timing chain/guide/rail stuff :(
euroshark - i can't take credit for it, but glad it helps!Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
G265 - Removable bellhousing ( far easier to remove once in the car, 4 bolts and out FTW)
Just to help clear things up alittle more.///Monstrosity. (OO≡≡[][]≡≡OO)
Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
Yep, and then there is like 3 different versions of G260 (m20, early m30 and late m30 iirc)Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Alright so today I spent about 6 hours taking the b35 all apart and need to order a couple more parts. The timing tensioner, guide/rail and maybe the oil chain tensioner or whatever it's called. I wasn't planning on doing a head gasket, but I figured might as well do it now and make sure block isn't cracked like my m10. Pulled the head and looks like the crosshatching is fine, and block isn't cracked. I am not sure if I want to pull the end caps and inspect the bearings, I need to price them out and maybe I'll just do that. But then it get's close to, should I pull the pistons out too and get the block hot tanked as well? have to draw the line somewhere... sigh.
The only thing that I am worried about a little is the color of the exhaust valves? Is that normal?
On to the pictures.
Note the color of the exhaust valves
large image here
head coming off
was leaking a bit from the top gasket
yay for useless mounts
misc parts
exhaust and a/c parts
parts to hot tank
Are m30 head bolts re-usable ?
crosshatching
wish the oil pumps weren't $$$
more parts to order
Maybe this oil chain tensioner part as well?
tensioner stuff
this won't be going back in
Loks like it's coming along great!
The head bolts should be replaced whenever the head is removed. They are stretch bolts = one time use.///Monstrosity. (OO≡≡[][]≡≡OO)
Alright. As much as I want to do the bearings and rings I think I'll leave those alone after adding everything up in my shopping cart.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
they are not stretch bolts, thats the m20 head bolts,
so you can reuse them, but it seems like you are really doing things right, there is no sense and not replacing them for peice of mind, they are cheap.
the tear down is looking good, keep up the good workComment
Drive-shaft arrived, looks like u-joints were serviced. I checked the movement and it's smooth from what I can tell w/o any binding.
Radiator/Tranny/Mounts haven't arrived yet.
The white stuff is packing material...
Yep, I am ordering 11311253236 timing chain guide/rail, 11311262273 timing chain rail, 11311744347 tensioner piston and A6035-72779 oil pump chain tensioner as well. Will probably get new head intake and exhaust studs and copper nuts as well since they are cheap.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
