E30 M30 Wiring
  • Topper03
    • Apr 2019
    • 7
    E30 M30 Wiring
    Hello,
    I am currently working on a track-only e30 that i plan on putting a turbo m30 in.
    I am currently working on stripping out the interior, including the chassis loom/wiring. My chassis loom has clearly had some "work" done to it, and is wrecked. It's a complete bird's nest, has random wires spliced together, and literally had wires coming off in my hands as I tried to unplug various connections in the dash.
    It's so bad that I've decided to completely strip out the wiring and wire up only what I need from scratch. I will not be using the factory ignition location, fuse box, etc.-- including the c101 connector.
    My question is:
    What, if any, connections does the m30 ECU need from the c101 to run?
    I'm not concerned about information from the ECU to the chassis like the tachometer or speedo, as I can wire up that sort of thing as needed.
    Thanks!
  • ForcedFirebird
    • Feb 2007
    • 8300
    Only a few wires are needed. Geen wires are ignition, black/yellow is starter engage, blue is alternator charge exciter, green/purple is fuel pump.
    Use the ETM for the donor car and look for the c101 connections to be sure.
    john@m20guru.com
    Links:
    • Topper03
      • Apr 2019
      • 7
      thanks for response. are these wires information or power? for instance, is the green/purple wire telling the ECU that the fuel pump is on or is it providing power to it?
      thanks again.
