'93 318i dies on acceleration
  • Dingo76
    • Jul 2021
    • 9
    It starts well and idles ok. Thru most driving conditions it runs well..but accelerating from a stop causes it to bog or stall...i really have to get rpms up to get thru that stage
    any suggestions welcome
  • bmwman91
    • Oct 2004
    • 3134
    Is the issue related to vehicle speed, or engine RPM?
    If it is RPM-related:
    Change the fuel filter and maybe see about getting the injectors cleaned.
    Is the original catalytic converter in there still? Although rare, it can fracture and block the exhaust.
    There could be wear in the air flow sensor which will cause the ECU to cut fuel.
    Dying ignition coils can also cause stuff like this.
    Transaction Feedback: LINK
    • Gregs///M
      • Mar 2012
      • 2459
      Vaccum leak, CPS or AFM.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • Dingo76
        • Jul 2021
        • 9
        Ign off, harness connected... I measure between 1 and 2 on AFM: 11.2k ohms...as I move the vane from air filter end, I get no change in reading...
        • Gregs///M
          • Mar 2012
          • 2459
          Cant use a meter to measure the AFM output. Meters take and display an average so when you are measuring it with a meter, you are actually looking at the average resistance. You can only use an oscilloscope while installed on the car or a 5v power supply. See my AFM thread for more info about how to properly test and AFM. But honest, Ive rebuilt many thousands of AFMs and never once seen one enter our shop that was consider "still good" after 30+ years.
          www.BavRest.com
          My Feedback Thread
          Our Facebook!
          • bmwman91
            • Oct 2004
            • 3134
            The AFM is not "just" a potentiometer, so as noted a resistance test means nothing. You will see the value fluctuate up and down as the vane opens due to how Bosch laser trimmed the carbon track and its pull-up taps. You need to put the car into accessory mode, have the AFM plugged in, pull the boot back and measure voltage across pins 2 (output) and 5 (ground). It should rise smoothly from ~0.27V to ~4.8V as you manually open the flap by hand. If there are skips or drops along the way, then the track is worn.
            • Dingo76
              • Jul 2021
              • 9
              Thanks bmwman .. will check that.
              meanwhile engine code 1222
              with Vac guage attached: warm start.. it idles st rock steady 18 for 5 mins or do, then at some point starts dropping steadily to 12 psi very rocky idle . Then 3 mind later it goes right back to 18... then a few mins later back to 12
