Anybody have any info or a DIY link to delete the AC system? I searched on here and m42club and e30tech but couldn't find any info on it. Thanks.
AC Delete mod
I've done a few (okay a bunch), any specifics you need to know? It's not all that complex.I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
Originally posted by kencopperwheat View PostSince when is deleting the AC a mod?
Does yours not work? You'll need to have it evacuated if there's still Freon in it.
after pulley is gone?1990 S50 goodness.
Here, I'll do a write-up:
Take it out.
Drink beer.
There, two steps.'89 325is S50 Track Montser
'04 X5 Daily/Tow Vehicle
http://www.avarestoration.com
http://www.myspace.com/brendanfiddle
Click here if you want to be my zombie slave...
http://www.youtube.com/user/Fidhle007
You can just cut the belt... it only goes from crank pulley to ac compressor.
I would just take out the compressor and condensor (and the accessable lines to each)... everything else doesn't weigh that much and is a PITA to remove.Originally posted by Grueliusand i do not know what bugg brakes are.
and the mounting block and pulley, a whole nother 4 bolts
if its a track car , get rid of the P.S. too
getting rid of all that and the resavoir, and the extra belt, really cleans up the engine and compartment
even my 5' wife can drive it, and does not complain about any extra effort
now get rid of the fan clutch and fan
you can wire the stock aux fans to kick on
now you have really cleaned up the engine compartment and picked up some HP too
Originally posted by isamemon View Postand the mounting block and pulley, a whole nother 4 bolts
now you have really cleaned up the engine compartment and picked up some HP too'89 325is S50 Track Montser
now you have really cleaned up the engine compartment and picked up some HP too1990 S50 goodness.
There are countless threads on here about how much people hate deleted power steering. You're gaining very little by removing it...'89 325is S50 Track Montser
Originally posted by CincinnatiKid View PostAnybody have any info or a DIY link to delete the AC system? I searched on here and m42club and e30tech but couldn't find any info on it. Thanks.
not to be an ass but you plan to track your car and you can't remove a/c components on your own. yikes. you're going to have a very tough road ahead of you. track cars need to be maintained more then dailies and things will break eventually. you need to just start working on your car and learn by experience and learn from your mistakes.
Originally posted by omar85 View Postnot to be an ass but you plan to track your car and you can't remove a/c components on your own. yikes. you're going to have a very tough road ahead of you. track cars need to be maintained more then dailies and things will break eventually. you need to just start working on your car and learn by experience and learn from your mistakes.1990 S50 goodness.
