AC Delete mod
  • CincinnatiKid
    • Nov 2007
    • 716
    Originally posted by mooseheadm5
    Take it to a shop to have it evacuated first, please. Don't vent that freon to the atmoshpere.
    I plan on it thanks.
    1990 S50 goodness.
    • Fidhle007
      I can fly, motherfucker
      • Oct 2005
      • 7209
      I had an A/C system blow up in my face the other day, not fun. I was very cold and covered in compressor oil and had a cut on my arm where the loose line flew up and hit me. Make sure that shit is empty before you fuck around with it...
      '89 325is S50 Track Montser
      '04 X5 Daily/Tow Vehicle
      http://www.avarestoration.com
      http://www.myspace.com/brendanfiddle
      Click here if you want to be my zombie slave...
      http://www.youtube.com/user/Fidhle007
      • mooseheadm5
        • Apr 2009
        • 375
        You will find that it is just hoses and bolts to remove the AC bits. Seal all the ends of the hoses in case someone wants to use it later.
        -P
        Moosehead Engineering
        • Liam
          • 753
          Originally posted by Fidhle007
          Picking up horsepower on an M42 is like coming out at... Never mind.
          :finger:
          I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
          • 87e30
            • Jul 2008
            • 5676
            What if I can't get the car to a shop to remove the freon?
            The A/C wasn't working so it might not even be charged... But anyways I'm in teh middle of a swap and just want to yank out the A/C now.
            I just hate everyone.
            No need for discretion.
            • thereisnoyun
              • Feb 2007
              • 2301
              jsut do a quick test, push in the shrader valve and let some pressure out, if it immediately stops then its empty. If it keeps bleeding then stop.
              the other thing to test, is to see if the ac engages, since it has pressure fail switch, if there is no pressure or insufficient pressure the compressor wouldnt turn on. Given you ahve ot know if hte compressor was working before hand.
              • 87e30
                • Jul 2008
                • 5676
                The belt wasn't hooked up when I got the car. I now have no engine. So I don't really know if it's working.
                I'll go push in teh shrader valve and see what happens.
                If it is still under pressure what can I do with all of it besides taking it to a shop?
                Edit: LUCKY ME! There was no pressure... I will start ripping everything out. :)
                Thanks for the quick response.
