TPS wiring had some wires spliced in using crimp connectors. I replaced the spliced in wires with some heat shrink "solder" connections and new wire. Then tested at the ecu connector to confirm connection.
The fuel filter is new but it is rather small. I have not check fuel pressure, it is on my list of potential issues.
I assume those crank sensors are made in different facilities with different quality of components. Plus the OEM one gets that OEM markup. Honestly had I known how pricey m42 parts are I probably would have stuck to the m10...
It's weird that the afm filter was completely blocking out the signal for me then.
