M42 alternator
  • Creamchez
    • Sep 2022
    • 6
    M42 alternator
    Hello, I hope to find a answer to my question. My alternator just died on my e30 m42 318i. I’m found one that’s 90 amps but unfortunately they are out of stock in my local parts stores. Then I found a 105amp alternator for a e36. Is the alternator for the e36 m42 a direct fit for the e30 m42?
    This is daily so I am hoping to pick one up instead of waiting for shipping.
    Here’s the part number for the e36 alternator I’m looking to buy: R110803A
  • jsnppp
    • Jan 2021
    • 260
    Hmm, can you cross check part numbers on major part supplier websites?
    My guess is that it should be the same but I don't know for sure. One option is to carry in your old one and check it side by side for the big dimensions and the electrical plug.
    Jason
    1991 BMW 318is - AlpineWeiss II
    1991 BMW 318is - DiamondSchwartz
    1973 BMW 2002 Tii - Baikal
    2002 Toyota 4Runner SR5 sport - Black
    • jsnppp
      • Jan 2021
      • 260
      I just checked and Oreilly's says it won't fit an M42 '91 318is. So - must be different.
      Jason
      • roguetoaster
        Biggus Tippus
        • 7826
        I think the bolt spacing is very similar, but the spacing where the bracket goes may be somewhat smaller on the E36 M42/44 unit. Only way to be sure is to measure the two.
        Otherwise, ebay will have alts if the locals don't.
        • monty23psk
          • Mar 2008
          • 1289
          I thought the e36 has serpentine belt pulley. Is that true?
          Alex 88 m5 | 91 318is | 19 Subaru Ascent
          BMW Tool Rentals & Fender Roller
          • roguetoaster
            Biggus Tippus
            • 7826
            Most models have pulleys that can be swapped, albeit some will need a small spacer or a different washer. But the E36s with M42s will almost certainly be v belt. Many years ago I was working on a serpentine belt conversion for an E30/M42 and I was able to simply install an E36 serp pulley IIRC.
