M42 surging idle is fine when ICV unplugged!
  • unixnerd
    • Mar 2016
    • 20
    My M42 idles roughly and sometimes stalls at idle when warm. Perfect when cold.
    If I unplug the ICV the warm idle is perfect at 800rpm! I've cleaned the ICV and it seems fine. I THINK the ICV is open when unplugged, closed under power. So by unplugging it I'm letting in more air (I think!).
    TPS gets 3.9kOhm pins 1-3, 1.7->4,4k pins 1.2 depending on throttle position. There is a tiny bit of slack in the throttle cable at idle. I think this is a good test.
    I did the "mess under the intake" pipework cleanup a few years ago and deleted the throttle heater so my air piping is newish as are all of the intake gaskets (inc. manifold). Don't think it's a vacuum leak.
    Car runs perfectly except for warm idle.
    Any thoughts? I'm suspecting the TPS or the wiring to it.
    My BMW site: www.unixnerd.co.uk since 1996
  • Dj Buttchug
    • Jun 2010
    • 7686
    I would smoke test your intake system first and see what you find. Also check your throttle body boot for cracks.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • unixnerd
      • Mar 2016
      • 20
      Wish I had a smoke tester! Can't see anything, will have another look........
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5599
        Just spray some brake clean around the intake and hoses and see if your idle speed increases.
        • monty23psk
          • Mar 2008
          • 1289
          if you smoke cigars, grab a full bodied one and find one of the hoses at the end to push smoke through. Or you can build a smoke can, with diesel plug, baby oil and a can.
          Alex 88 m5 | 91 318is | 19 Subaru Ascent
          BMW Tool Rentals & Fender Roller
