Strange stalling issue
  • ethirdy
    • Nov 2007
    • 406
    Car is a 1991 318i. Approx 142k miles on it, 5 speed.
    After starting, car will idle ok, but as soon as you push on the throttle, she sputters and dies. If I LIGHTLY press the throttle, and push slowly, I can get the engine all the way up to redline, holding it anywhere in between. Any faster input to the throttle and she sputters and stalls.
    Changed DME, AFM/MAF, and TPS.
    What's next?
    Originally posted by alpinaclone
    Since the real economy is in the shitter, I say we start our own.
    This is how it works; you buy my junk, then I will buy more junk and so on so forth etc. etc. Think of the future of your children and buy my stuff.
    • 34847
    how is the fuel pressure?
    • tjts1
      • May 2007
      • 1851
      Vacumm leaks.
      • ethirdy
        • Nov 2007
        • 406
        What's the best way to check fuel pressure on an m42? Sprayed down for vacuum lekas couldn't find any
        EDIT: Swapped the fuel pump(was louder than it should be) with fuel pump from 91 325ic - car runs perfect now :)
        • e3o-master
          • 65
          careful
          convertible pumps are different then regular sedan and coupe pumps
          • ethirdy
            • Nov 2007
            • 406
            How so?
            • Cobra Jet
              • Apr 2008
              • 278
              Originally posted by e3o-master
              careful
              in what way????? Never heard such a thing.. Please provide facts, as the statement makes no sense. One can purchase an aftermarket Walbro fuel pump that is NOT manufacturer/make/model specific and install this same pump in either a standard coupe, sedan or convertible with no adverse issues - and the install/wiring is the SAME on all 3 models...
