Afternoon folks,
My girlfriend bought a 91 318 with engine trouble. Doesn't run, nasty chain noises from the PO. I took the valve cover off and there was a LOT of chain slop, it could move perhaps 2 teeth. Appears the tensioner wasn't doing its job. I convinced it back to proper timing (BTW, is there a front of engine TDC mark, as the flywheel has no hole.. And its stock according to my service history..) and did a leakdown, #1-3 95%, #4 40%. Pulled the head, the valves are obviously bent, its going to be sent out to be rebuilt (surface, new guides/seals, replace needed valves, valve grind).
So, in regards to the chain, do I want to just put a new tensioner piston in, or should I pull the lower cover and replace the chain too? The guides have minor wear (180k on the car IIRC), so I don't think they failed...
Any input is well appreciated!
-Roman
-Roman
:wgaf:
