Cheap/Basic M42 Mods.
  • freeride53
    • 11972
    What is out there?
    I've done some searches, but I want to see what could happen first-with a budget.
    The car at hand is a 1991 Bmw 318i 4d. (m42 as yall know)
    I've been reading about chipping, which is the best, and provides the best hp gain? also, exhaust, intake, etc.
    This is a highschool/d.d/fun car that I'm working on getting all together so I can retire the Peugeot to a weekend/occasion car.
    1983 Peugeot 505 STI
    1992 Volvo 240 Wagon
  • fiftytakedowns
    • 2460
    mark D / WAR chip are the two best
    Intake Is not so much a mod UNLESS you go Headling intake which DOES improve the car. Superspring/ REMUS/ Stromung or GTFO
    Regrind Cams are an option for 300 bucks
    m20 flywheel is a cheap option too for performance.
    Or get a Supra motor?
    [/url]
    Team USA Wrestling 67KG
    • White325is
      • Oct 2006
      • 5947
      I think the exhaust on the M42 is already stock at 2 1/4 you should jump up to 2 1/2 a better cat and muffter setup. The summit racing turbo muffler sounds awsome on the M42's. My buddy had a MarkD chip on his M42 and it made a big big improvment. Its pretty much the best bang for your buck.
      • freeride53
        • 11972
        hmm.
        i've heard about m20 flys, i think i'm going to for sure opt for one of those. those are off the 325's right?
        lol...2-jay-z?!
        i will keep the car original-bmw.
        and the car will be staying with the M42...till maybe i'm out of college, and thats a far way down the line.
        I wanna have a car that wont take shit from my friends' integras, subar-whos, yotas, etc..
        i wanna do a 5-lug soon, and throw something like some m-system throwing stars on, and do the suspension all up, and do a lsd.
        • ethree
          • Aug 2007
          • 1216
          Should of bought a wrx if you wanna keep up with wrx's. Mostly stock tegs and most things 6 cylinder and/or turbo from toyota will also beat m42 powered cars.
          There's a ti in the south san jose pick n pull for your 5 lug setup.
          • SamE30e
            • Sep 2007
            • 4319
            No need to upgrade the headers they're already a tubular setup.
            1985 325e 2.8 Turbo VEMS
            • 2002maniac
              • 4260
              The ONLY worthwhile mod on a street driven M42 is a chip. I have used both MarkD and Turner and they are both great.
              Intake and exhaust will do absolutely nothing. A lightweight flywheel is nice, but not a power mod.
              • 2002maniac
                • 4260
                I've done cams too, they are awesome on the track but suck for the street.
                • Rob
                  • 8166
                  as per usual, making sure all the wear items/maintenance stuff on the motor is fresh will do more than most "mods", chips not withstanding...
                  BEERTECH
                  • dlmrun2002
                    • Apr 2007
                    • 808
                    Intake cam is adjustable. Advance it 4 degrees and get a chip.
                    • tjts1
                      • May 2007
                      • 1851
                      So you're going to take on that Integra after all?
                      :up:
                      • Slick92GS-R
                        • Apr 2005
                        • 662
                        it looks like BOTH intake & Exhaust cams may be adjustable .. (at least on my E36M42)
                        --Hayden--
                        '87 325 coupe- Trak Rat
                        '93 318is- 4cyl's of fury
                        '92 Integra GS-R--yeah, its fast..
                        www.G2IC.com
                        • E30SPDFRK
                          • 5715
                          Intake cam is adjustable. Advance it 4 degrees.
                          I've heard about this, but I thought I read 6 degrees. What kind of difference does this really make?
                          Byron
                          Leichtbau
                          • e30guydownunder
                            • Jul 2008
                            • 874
                            Pretty much a free-er flowing cat and rear muffler and chip are your best bang for buck mods.
                            RE: adjustable cams. The slots in the cam gears give you +/- 6 degrees on the standard settings. By moving them you can change the lobe seperation basically, all your doing is moving the power and torque curves around, you can get a few hp out of it but apparently absolutely kills your bottom end.
                            Take the heater plate out of the intake if you have it and dump a ton of old hoses just waiting to give you hell in the process.
                            Otherwise your looking at cams and a chip to suit.
                            The M20 flywheel is a nice mod, I've done it. You want a single mass M20 flywheel. And if you can bear it dump p/s and a/c. Also if you throw an electric fan on you can free up a few hp there.
                            - Chris
                            Project M42 - 255 @ 19 psi
                            • tjts1
                              • May 2007
                              • 1851
                              Originally posted by e30guydownunder
                              Altering the exhaust cam messes with the cam position sensor position (affecting ignition timing).
                              No it doesn't.
