whoops...i was referring to my bastardised engine....somebody had retarded the sprocket one tooth. editted to save misinformation
Cheap/Basic M42 Mods.
1983 Peugeot 505 STI
1992 Volvo 240 Wagon
2009 Toyota 4Runner SR5 Sport 4WDComment
Good man. You can use a lot of JY volvo parts. Here is the list:
22# injectors, See here.
960 cooling fan.
Ditch the PS pump. Drain the rack and block it off.
Get some spark plug wires off an 850. The 4 longest ones will fit the M42 perfectly. Way cheaper than M42 wires. I bet urs are toast.
Search fleabay for the proformance chip. It works. use 91.
Fix the intake
Ditch as much weight as you can.
good luckComment
RE: adjustable cams. The slots in the cam gears give you +/- 6 degrees on the standard settings. By moving them you can change the lobe seperation basically, all your doing is moving the power and torque curves around, you can get a few hp out of it but apparently absolutely kills your bottom end.
Not only will you shave a few pounds with the m20 flywheel, lower your rotational mass, but you'll be able to go to a single mass flywheel, which you can get resurfaced later. Most shops won't resurface a DM flywheel. M20 flywheel is a very worthwhile upgrade.Comment
Also, I've got a 318i. No LSD for me. Blew the stock open diff in the snow last year at 175k. I replaced it with a 2.93LSD. It's effectively turned my 5 speed into a 3 speed. It's a hoot around town. 43mph in 1st gear, 82 in second, 120 in 3rd, but not in 4th or 5th. No power to pull it. It's taken quite a few cars by surprise from a dig, not because it's got tons of power, or it's really quick, or anything like that, but because I don't have to spend the time on the 1-2 upshift. Had a few kills, surprisingly. Only problem is that stoplight-to-stoplight repeats are horrible, as the clutch is on its way out. Repeated launches end with slippage.Comment
I swapped in a 3.64 which made the car livable but I always wondered what would happen with an ETA diff. Maybe i'll try it just for shits and giggles.Comment
If I'm doing 65mph in 5th I can downshift into second and have 1600rpm left to wind out. If I do 65 in 5th on flat ground the car gets like 38mpg.Comment
Rob, my car's such a hooptie that it just fits. I'll have to take pics and put them up sometime.Comment
