inspiration, yo!
Cheap/Basic M42 Mods.
1983 Peugeot 505 STI
1992 Volvo 240 Wagon
Originally posted by ThaiRacer View PostWhat do u guys think about spray maybe like a 75 shot?
It's bad for piston rings and head gaskets, and it puts harmful sudden load changes on your drivetrain components.
If you're going to build a car for nitrous, to reliably handle a 200+ shot, props to you. But this requires a built motor, metal head gasket, special piston rings (there's a company called Hellfire that makes them), and strengthening/upgrading almost every piece of your drivetrain.Originally posted by accidentI have achieved the title of Douche of the month.
Discuss.Originally posted by kronusIt was probably pissed off because it didn't want to pay taxes for poor people's healthcare.
1991 318i 4dr 5spd (DD)
Originally posted by Schnitzer318is View Post
Had those and are great for top end power. I dyno'd 136 to the wheels with those, delete parasitic fan (efan), 4 pintle injectors (mustang), ebay proformance chip, and cleaned up vacuum lines. Warning though, you do lose a good bit of low end torque. When I put my stockers back in for the turbo setup, gained ALOT more torque below 3000rpm.Originally posted by Grueliusand i do not know what bugg brakes are.
what about hi comp pistons?FEEDBACK:
http://www.r3vlimited.com/board/showthread.php?t=316212
BMWCCA #398608
IG @yagayo38
"The Best E30's were built with two camshafts four cylinders and sixteen valves!".
Originally posted by 2002maniac View Postyeah, what's this talk of shortening the driveshaft? I'm positive the input flange is in the same place.
Plus shortening the driveshaft excessively and putting it out of the way makes it a bit easier to get the diff in position.
Originally posted by thedguy View PostTo the guys talking about regrinding the cams
What are a safe set of specs to go with an what can the factory valve train even handle? I know a little about cams, but never ordered a custom grind and about the only thing I know to do is to get in contact with Delta cams.
in his m42 and seems happy with it. you could check with both; even basic info on lift and duration would let you make something of a judgment call on which you want.
edit: also found these:
i would be very interested in the specs on the stock cams myself, if anyone has them.Last edited by decay; 03-03-2010, 07:49 PM.past:
1989 325is (learner shitbox)
1986 325e (turbo dorito)
1991 318ic (5-lug ITB)
1985 323i baur
current:
dk, Metric Mechanic and VACMotorsports have M42 cams as well as Webb and possibly DBilas.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
yeah, looking at the retail for my ITBs i don't think i'll be going with dbilas. not raking in the iraq money any more, which is why progress on my car has slowed so drastically. :)
i was asking about stock cam profiles because a trick i've seen used on VW and nissan twincams is buying a "sport" cam for the intake and then swap the stock intake cam over to the exhaust side. asked robert (peerless) about this and he thinks we could do the same on the M42.
anyway someone on m42club found the specs for me:
Application: O.E.M.
Duration [0.1mm+cl]: 255/255°
Duration [1.0mm+cl]: 207/207°
maximum lift [cl=0]: 9.70/9.70mm
Lift at TDC [cl=0]: 0.90/0.65mm
looks like it might not be worth the trouble but i thought the idea was worth investigating.
i will probably just go with delta regrinds like 2002maniac did. i've done enough weight and parasitic-drive reduction (ps/ac/clutch fan all gone) that losing a bit of low-end would probably just make it feel like it used to before; and another ~100lbs is going to come out of the car before i get around to this anyhow.past:
1985 323i baur
current:
www.catcams.com has cams for the m42 as well but i have no idea about cost (check out the chart below). They sell more agressive cams but they require different springs/lifters to install.
O.E.M.
255 / 255°
207 / 207°
9.70 / 9.70mm
0.90 / 0.65mm
O.E.M.
HYDR: O.E.M.
1301411
257 / 257°
215 / 215°
9.90 / 9.90mm
1.30 / 0.95mm
O.E.M.
HYDR: sport
1301413
269 / 269°
225 / 225°
10.00 / 10.00mm
2.05 / 1.55mm
O.E.M.
HYDR: sportLast edited by Voluted; 03-05-2010, 09:06 AM.
Even after the ltw flywheel I feel like I need some more oomph....
DK hows the PS loss? Im getting sick of it . but Im wondering about the safety (like hydroplaning, spinning out ETC.
I really wonder How much power we can get out of the m42 without doing internals.[/url]
Team USA Wrestling 67KG
Originally posted by Asbradley21 View PostI wouldn't put nitrous on an m42 period. Get a real motor.
Oh, and I own an M44 powered e36. It sounds like a lawn mower and just never idles as well as the I6s. I *much* prefer the M20 or M5x, neither of which are all that expensive to swap in and yield much more usable power.1997 540i/6 - stock
1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
