inspiration, yo!
Cheap/Basic M42 Mods.
1983 Peugeot 505 STI
1992 Volvo 240 Wagon
2009 Toyota 4Runner SR5 Sport 4WD -
Don't do it.
It's bad for piston rings and head gaskets, and it puts harmful sudden load changes on your drivetrain components.
If you're going to build a car for nitrous, to reliably handle a 200+ shot, props to you. But this requires a built motor, metal head gasket, special piston rings (there's a company called Hellfire that makes them), and strengthening/upgrading almost every piece of your drivetrain.Originally posted by accidentI have achieved the title of Douche of the month.
Discuss.1990 300ZX TT 5spd ($6,000)Originally posted by kronusIt was probably pissed off because it didn't want to pay taxes for poor people's healthcare.
1991 318i 4dr 5spd (DD)Comment
I wouldn't put nitrous on an m42 period. Get a real FI system.
S54B32 swap in progress. Status: Getting ThereComment
do you remember what regrind it was? 256? 270?
Had those and are great for top end power. I dyno'd 136 to the wheels with those, delete parasitic fan (efan), 4 pintle injectors (mustang), ebay proformance chip, and cleaned up vacuum lines. Warning though, you do lose a good bit of low end torque. When I put my stockers back in for the turbo setup, gained ALOT more torque below 3000rpm.Originally posted by Grueliusand i do not know what bugg brakes are.Comment
what about hi comp pistons?FEEDBACK:
http://www.r3vlimited.com/board/showthread.php?t=316212
BMWCCA #398608
IG @yagayo38
"The Best E30's were built with two camshafts four cylinders and sixteen valves!".Comment
The driveshaft is telescopic. The flange on yours may have been loose and you without noticing adjusted the length of the tailshaft. It is a very minor change in length.
Plus shortening the driveshaft excessively and putting it out of the way makes it a bit easier to get the diff in position.Comment
To the guys talking about regrinding the cams
What are a safe set of specs to go with an what can the factory valve train even handle? I know a little about cams, but never ordered a custom grind and about the only thing I know to do is to get in contact with Delta cams.
i don't have anything about specs for you, but a friend has an intake cam from these guys:To the guys talking about regrinding the cams
in his m42 and seems happy with it. you could check with both; even basic info on lift and duration would let you make something of a judgment call on which you want.
edit: also found these:
i would be very interested in the specs on the stock cams myself, if anyone has them.Last edited by decay; 03-03-2010, 06:49 PM.past:
1989 325is (learner shitbox)
1986 325e (turbo dorito)
1991 318ic (5-lug ITB)
1985 323i baur
current:
1995 M3 (suspension, 17x9/255-40, borla)Comment
dk, Metric Mechanic and VACMotorsports have M42 cams as well as Webb and possibly DBilas.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
yeah, looking at the retail for my ITBs i don't think i'll be going with dbilas. not raking in the iraq money any more, which is why progress on my car has slowed so drastically. :)
i was asking about stock cam profiles because a trick i've seen used on VW and nissan twincams is buying a "sport" cam for the intake and then swap the stock intake cam over to the exhaust side. asked robert (peerless) about this and he thinks we could do the same on the M42.
anyway someone on m42club found the specs for me:
so everything is the same except the lift @ TDC. am i reading it right when i think that means they're basically the same except the intake cam has a more convex ramp? or is it just that TDC just falls on a different place in the "bump"?Application: O.E.M.
Duration [0.1mm+cl]: 255/255°
Duration [1.0mm+cl]: 207/207°
maximum lift [cl=0]: 9.70/9.70mm
Lift at TDC [cl=0]: 0.90/0.65mm
looks like it might not be worth the trouble but i thought the idea was worth investigating.
i will probably just go with delta regrinds like 2002maniac did. i've done enough weight and parasitic-drive reduction (ps/ac/clutch fan all gone) that losing a bit of low-end would probably just make it feel like it used to before; and another ~100lbs is going to come out of the car before i get around to this anyhow.past:
1985 323i baur
current:
www.catcams.com has cams for the m42 as well but i have no idea about cost (check out the chart below). They sell more agressive cams but they require different springs/lifters to install.
O.E.M.
255 / 255°
207 / 207°
9.70 / 9.70mm
0.90 / 0.65mm
O.E.M.
HYDR: O.E.M.
1301411
257 / 257°
215 / 215°
9.90 / 9.90mm
1.30 / 0.95mm
O.E.M.
HYDR: sport
1301413
269 / 269°
225 / 225°
10.00 / 10.00mm
2.05 / 1.55mm
O.E.M.
HYDR: sportLast edited by Voluted; 03-05-2010, 08:06 AM.Comment
o0o0o sounds fun!
[/url]
Team USA Wrestling 67KG
Team USA Wrestling Strength And Conditioning CoachComment
Even after the ltw flywheel I feel like I need some more oomph....
DK hows the PS loss? Im getting sick of it . but Im wondering about the safety (like hydroplaning, spinning out ETC.
I really wonder How much power we can get out of the m42 without doing internals.
[/url]
fixed. The m42 has its place, but overall, it's near the top of its game barring expensive mods and even afterwards is largely gutless. I'd much rather have a torquey motor than a high revving one. In race applications, I can see a built M42 being nice. For the street... I'll take an I6.
Oh, and I own an M44 powered e36. It sounds like a lawn mower and just never idles as well as the I6s. I *much* prefer the M20 or M5x, neither of which are all that expensive to swap in and yield much more usable power.1997 540i/6 - stock
1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDsComment
