Temp Gauge Issues - I need Help!
  • cabin
    • Dec 2006
    • 552
    Here's the issue, my temp gauge does not work at all when the car is started, it just stays in the "blue" and will not budge. However, when the ignition is turned to acc. the gauge will go all the way into the red and stay there until the car is started.
    This all started after doing the mess under the intake mod. Before this, the gauge worked as it should. I am thinking that maybe I forgot to connect a ground, or something got bumped.
    Before anyone asks, the plugs are not switched for the two temperature sensors on the head, I have made sure of it. I should also add that both of those sensors are brand new, thinking that they were the culprit.
    I really have no idea where to go from here. I checked all of the wiring and it looks just fine, no exposed wires or potential locations for shorts.
    If anyone has any ideas, throw them out there, I am sick of chasing this stupid problem! At this point, I am thinking about just buying an aftermarket gauge, but I would really like to avoid it.
    -Justin
    Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
  • Jean
    • 18228
    When you disconnect the temp sensor plug and short it out does the gauge move?
    • cabin
      • Dec 2006
      • 552
      Have not tried that, but I will give it a shot today. If it does/doesn't move, where do I go from there?
      Thanks for the help.
      -Justin
      • Yeee30
        • Nov 2005
        • 799
        Bring back from the dead. Any more info on this. I have the same problem. Thanks in advance.
        [PAKSIW]
        20D .........
        vmwerks :up:
        ryan gmw :up:
        • Dj Buttchug
          • Jun 2010
          • 7688
          mine does the same thing... I quit fighting it.
          Invest in this: http://prosportgauges.com/52mm-elect...ure-gauge.aspx
          it works awesome and is sooooo easy to install
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • bmwm42
            • 6300
            Si board or the board on the cluster you can also check and make sure the nut on the back of the gauge is nice and tight because that is ground for the gauge
            Originally posted by bmwm42
            PNW vulture pm me for parts
            Strategic nw e30 command
