Car dies won't start
  • trackjunkie21
    • Jan 2010
    • 3962
    So driving down the parkway doing about 50mph at around2,000 rpm and all of a sudden the car dies and the starts back up. Then after I get off the freeway and stop at a light and the car dies in the middle of the intersection and won't start back up. I try pumping the pedal still nothing. Finally started and drove it home without a problem. I don't get it. The crank sensor has just been replaced and it feels like there is no spark? Cam positioin sensor need replacing?
    Originally posted by Wh33lhop
    VANOS: sometimes you just need to go full retard.
  • VoskaOhrid
    • Jul 2010
    • 37
    bump , same problems
    • KenC
      King of Kegstands
      • 14396
      Use a multimeter to check the cam and crank position sensors. Also try swapping in a known good ECU.
      Originally posted by Gruelius
      • Ryann
        • 3350
        An AFM that's crapping out will do this same thing. Try performing the stomp test to retrieve any stored diagnostic codes to get yourself pointed in the right direction.
        • trackjunkie21
          • Jan 2010
          • 3962
          Thanks guys, I did the stomp test and the code for the Lambda control came up. I cleared it and it never came back, but the problem still occurs.
          • Dj Buttchug
            • Jun 2010
            • 7688
            yo trackjunkie..... guess what i got today.
            THE DAMN LAMBDA CODE FML :hitler: :hitler: :hitler:
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
